I have a digital multimeter ans when I measure the voltage forward on some 2N5133 transistors I get measurements like .812 and .820 but I have read that good readings are around 300?
How do I convert the .8xx measurements?
Testing 2N5133 Transistors Voltage?
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
http://www.repairfaq.org/sam/semitest.htmmattpas wrote:I have a digital multimeter ans when I measure the voltage forward on some 2N5133 transistors I get measurements like .812 and .820 but I have read that good readings are around 300?
If not all, it does answer a lot of questions concerning transistor testing.
But 0.8V is good for a silicon transistors forward voltage drop, if I read correctly. How exactly did you measure it?
