Tetrafuzz
Vitallka
Been thanked: 100 times
Post by Vitallka »
Hi to all.
Maybe you, like me, have a lot of germanium pnp transistors that have a small beta (20-30)? And you don't know where to apply them? I have the same problems :)
And I thought that it is possible to apply them somewhere and found some solution. The essence of this solution is as follows: the first stage should be a silicon npn transistor to significantly amplify the signal and solve ground problems, then two stages on germanium pnp transistors, and then a silicon npn transistor repeater (again to solve ground problems) .
After some simulations and practice in reality, the following scheme was born:
And here I recorded through a tube amplifier and a dynamic microphone:
https://app.box.com/s/ujg4as6d2fdwsxdervft77qiuaireocc
https://app.box.com/s/8g0xgl5ukdfg39vdq8thacvq9rpi61cw
https://app.box.com/s/yfpl0occpcthnlg17j4ykl54sob5bbyg
In addition to MP26 transistors, which I used, you can try any other pnp germanium transistors, even with a beta that is less than 20. And capacitor C5 can be connected via a switch - the boost mode will be disabled.
TWSpedals
Has thanked: 18 times
Been thanked: 51 times
Post by TWSpedals »
This is cool. My solution for crappy germaniums is to couple them with a silicon transistor in a szikali pair.
Have a nice day!
Manfred
Has thanked: 1659 times
Been thanked: 1341 times
Post by Manfred »
Great development, sounds good to me ! :thumbsup
Vitallka
Post by Vitallka »
As an experiment, I decided to put a 2n7000 transistor in the first stage and this is what came out of it:
https://app.box.com/s/v1avb6l3zpow55x5330naqusn5ep8ku5
https://app.box.com/s/jgsh12okdvn233bd3bfkvfi7dj8u3dbi
https://app.box.com/s/l571m0h6s8vfr87178f3n6jzqz92h9ke
Ichabod_Crane
Has thanked: 80 times
Been thanked: 36 times
Post by Ichabod_Crane »
What's difference you can hear with mosfet instead BJT transistor?
Vitallka
Post by Vitallka »
It seems to me that with 2n7000 the sound is softer and more blurred, and with bc547 the sound is slightly sharper and clearer
Vitallka
Post by Vitallka »
I found an error in the diagram. Resistor R18 should be 10K, not 1K
Vitallka
Post by Vitallka »
Made some changes to the diagram, as there was an extra hole in the case, and corrected some inaccuracies in the diagram.
