tc-helicon harmony singer disassembly
rocklander
Has thanked: 1406 times
Been thanked: 231 times
Post by rocklander »
hey all ..long time no post from me.
I've a TC-Helicon harmony singer that's got (I suspect) dry joints on the AC input socket.
happy to sort out that simple job buuuutt.. disassembly is not so simple. I've removed all screws and the thing (built pretty darn solid) wont come apart (base from upper housing).
anyone know the trick to get these apart?
fwiw, their service site appears to have the odd loophole, so I found the schematics (link below).. if the link gets tightened up I'll post here if anyone is interested... prolly not exactly DIY stuff tho?
https://service-tcgroup.tcelectronic.co ... nger_2.asp
rocklander
update. I got a bit 'firmer' with it (wasn't sure I wouldn't break something).. but it's built with the USB socket 'notch' that is very tight. pics attached, but had to leverage with a screwdriver from the bottom end (footswitch end) to push the usb socket inside far enough I could just squeeze it past.
