Gila_Crisis wrote:@ Astrobass: I already added once that EQ circuit from the Boss Hyper Fuzz to a superfuzz "pimped" clone (if you search the pots you'll find a schem of it). For more clarity I like to use an OPA2132 or a OPA2134 for its opamp.
Neat!
I actually went a little further with it and posted a thread in the DIY forum as it was getting off topic here. I made the thing into its own effect and added a second dual op amp, using one side as input buffer and the other as a gain stage on the output. So it's a standalone tone stack/boost.
The TL072 at 18V does a great job, and it actually does nice things with a lot of fuzz pedals and older designs like the Electra, which lack really robust tone controls. Tames the highs and does a good job of shaping the high and low end response. The boost capability is also really nice to have, you can put it in front of a fuzz to slam it harder, or at the end of the chain to provide a low impedance, high volume signal through a long patch to the amp.
I'm super pleased with how it turned out, and as soon as my shipment of 3PDTs arrives, this thing is making a permanent entry onto my pedal board.
