Univox - Superfuzz  [schematic]
ShortScaleMike
my favorite amplifier: Marshall JCM800
Has thanked: 19 times
Been thanked: 92 times
Post by ShortScaleMike »
haha, it's Mike, but glad you have it working anyway, always a satisfying feeling!
From looking at other Octave Fuzzes like the Foxx Tone Machine, I would suspect that it is the Q3 emitter path 10uF 470 junction you want to break to cut the Octave effect.
Solidhex
Has thanked: 10 times
Been thanked: 15 times
Post by Solidhex »
Hmm
Wonder if sticking a pot in there and putting in some series resistance would let you blend in the octave. The usual 10k octave balancing trimpot does it a little...
--Brad
salocin
Been thanked: 7 times
Post by salocin »
Thanks for the layout Mike. Just got mine finished and it's great!
Here's how it came out:
Unfortunately it's for someone else so will be building another for myself straight away.
ShortScaleMike
Wicked, always great to see when people use the layout. That's a great looking pedal.
metulmykul
Post by metulmykul »
Finally got one of these together on the weekend.
Many thanks to ShortScaleMike for his layout and all who had input on it.
I can say that this build is a whole lot better to my ears than the Leeds Fuzz kit that i built. Both use 2SC828s but this has an unadulterated rawness that leaves the BYOC somewhat sterile in comparison.
How a fuzz should be in my opinion :twisted:
ShortScaleMike
Nice to hear, good stuff!
theblackman
Completed builds
tremulus lune, green ringer, big muff, ts808, the crank, harmonic percolator
Post by theblackman »
this is a great sounding fuzz, i was bashing out some riffage through my octane 3 yesterday which is the same circuit AFAIK
“Dream as if you'll live forever, live as if you'll die today.” James Dean
Nikifena
Been thanked: 35 times
Post by Nikifena »
I make this pedal maybe before more than 5 years.
Here is it:
It's good pedal, but right now I preffer to use a few schottky diodes instead normal 4148 diodes.
MJS11
Post by MJS11 »
I am new to this and was wondering if anyone can help with a wiring diagram for the layout posted here?
Has thanked: 3432 times
Been thanked: 711 times
This one contains wiring information, else you should check the schematic on the first page
https://www.freestompboxes.org/viewtopic.php?p=37093#p37093
Caillan
Post by Caillan »
I have tried to add a DC jack to plug into an adaptor, now my fuzz keeps dieing! I have traced the problem to something going wrong in the pots, so I replace them and they work for a while then something happens and they die again... any ideas as to what I might have done wrong??? I'm completely stumped!!
Solidhex
Post by Solidhex »
Yo
You most likely wired it wrong...
Its interesting the amount of components for the Superfuzz. Lots of transistors for a fuzz. I think the fuzz and octave seem to have a richer, deeper tone to it than most diode clipping octave fuzzes. Is that second transistor really needed at all. The buffer after the first stage?
--Brad
salocin
Post by salocin »
Caillan wrote:I have tried to add a DC jack to plug into an adaptor, now my fuzz keeps dieing! I have traced the problem to something going wrong in the pots, so I replace them and they work for a while then something happens and they die again... any ideas as to what I might have done wrong??? I'm completely stumped!!
I had a similar problem. It would work for a minute or two and then slowly die over about 30-40seconds. Turned out I had accidentally cut a track which, from memory, was just after a cap around q2.
I also had problems with a bad solder joint on one of the pots so check them too (even if they look fine!)
Caillan
Post by Caillan »
Yeah, I had built a working circuit from an etched PCB, but of course I felt the need to add a few little modifications (DC jack, power starve pot...) and (typically) now I've ruined everything!! I am pretty sure its a power source issue, my DC jack is wired as such..
Please let me know if I have done this wrong, it's the first time I have tried adding a DC jack so frankly I'm just taking stabs in the dark!
ShortScaleMike
switch the 9v battery and 9v circuit connections and you're golden.
Caillan
Post by Caillan »
Argh, still nothing.. I did a bit of probing with my handy ol multimeter and found that there is absolutely no current running through the pots, ideas??
devastator
Been thanked: 22 times
Post by devastator »
Anyone tried to change the tone switch to a potentiometer like zvex did on his Octane 3 ? That can allow more sound possibilities.
I saw a lot of fuzz pedals use this tonestack.
ShortScaleMike
Don't measure current. Measure voltage and start with the places you're expecting to see +9V, ground, and bias (on the transistors).
Debugging can be frustrating but it is actually very simple. Check everything methodically and you will find the problem. Presume nothing. Verify everything.
skumberg
Post by skumberg »
ShortScaleMike wrote:Thanks for teh corrections Graeme, this is now a verfied layout:
Hello Mike, I've been looking for a SF layout and was thinking about building yours, after looking att schematics shouldn't there be a 100k to ground at the output?
Would an external 10k pot be useful to balance Q4 and Q5 or is that a set and forget thing? I see you have used the schematic whitout the 10k trim found on some schematics so maybe somebody else knows?
Nicklas
ShortScaleMike
Obviously we are looking at different schematics. My layout is accurate for the one I used.
There were multiple variations of this thing by various different companies.
