i got a question about the tremulus lune.
if i don't build the LFO speed led can i leave those componets away? (red circle) or should i only put a 2k resistor going to ground?
plus i've done a vero layout for the last Revision (you can find the schem on commondsound). can someone please check if it's all right? one thing i didn't put is the LFO Led, but if necessary i'll add it.
here you go:
i have a question about the LFO led, i wanted to use it as a on-off status led also, but i don't have 3PDT but only DPDT. so can i use the millenium bypass to turn on and off the LED?
