- I used a 10k linear pot but a different taper (log or audio I suppose) would let you omit R6.
- My schematic says "opamp_quad" but feel free to ignore that and use a TL071 or similar.
- D5/D6 LEDs are 2.5v high-efficiency types, and they're just to prevent opamp saturation with large signals. They do light up when I crank the gain and play loud with single coils, but I don't think they contribute much to the sound.
- All non-LED diodes are 1n4148.
- simulation: https://tinyurl.com/2avb3xqb
Bagel - a soft but lightly toasted boost/buffer
- earthtonesaudio
- my favorite amplifier: haven't found it yet
- Completed builds: Metal Simplex, Fuzz Factory, two Fab Echos-modded, Noisy Cricket, Earth & Space Wah, TS-7-modded, passive xover/splitter box, opamp fuzz, various overdrives and boosts
- Has thanked: 14 times
- Been thanked: 99 times
- Contact:
This is the most recent refinement of a generic boost/buffer circuit I've been using for a while. It's a soft clipping boost with a subtle crunch, like a perfectly toasted bagel. Bypass scheme inspired by Valve Wizard, diodes-to-ground soft clipping inspired by Thunderbird (and discussed in this thread).
