Relocating a hum balance point?
theehman
Has thanked: 97 times
Been thanked: 102 times
Post by theehman »
I'm fixing up a friend's old Stromberg-Carlson amp for his use w/ guitar. I want to set up the output tubes (2x6L6) to have separate cathode resistors and capacitors. The one problem I'm having is that the filament winding has a 100 ohm hum balance pot with the wiper going to the (presently) tied together 6L6 cathodes (which has 25v according to the schematic). Should I just take the wire and connect it to ground or is there some place better to put it so it's getting a similar voltage?
Ron Neely II
fx schematics and repairs
You could probably attach it to the cathode of just one of the output tubes and get the same result. There is also the possibility of using a largish resistor (like 220K or something like that) to tap off from the B+ line to give the bias voltage for the hum balance.
Or, you could just attach it to ground... that might increase the hum... or it might not make any difference. I can't predict whether biasing the filaments in that particular amp would make a big difference or not.
Personally I would not connect it to the cathode of one tube, instead I would connect it to ground. Some audiophiles indeed connected the center tap to the V+ line, the reason is tube architecture and electron flow - a too long story for now. Since this should become (only) a guitar amp......
