Shannon Overdrive.
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
Another TS...but VERY well built. He no longer builds pedals.
GUT SHOT
http://img.villagephotos.com/p/2004-11/897786/sod4.JPG
Has thanked: 218 times
Been thanked: 857 times
Interesting riddle:
How does he solder the jacks.
as for the build (from a "I hate wires" perspective)... WOW. This is my guy! A design optimized for easy production.. Cool!
JHS
Been thanked: 5 times
Post by JHS »
Jacks are the version with nail contacts for PCB-mounting.
JHS
Hi Dirk
He solders the jacks last - the board is assembled minus the jacks - the jacks are inserted in the case upside down - the board is soldered to the jacks, then it is pivoted on the jacks and the pots nuts are fitted etc.
Goop_buster
Been thanked: 7 times
Post by Goop_buster »
Dirk_Hendrik wrote:Interesting riddle:
Isn´t that just jacks with PCB-pins? edit...oh well, bajaman allready told the story :lol:
As for "get rid of wires" it certainly looks neat but I think that any part that has some sort of potential for physical stress on it (jacks, pots or switch etc) should preferably be connected with wires. This is a hassle, takes a lot of time and certainly do not look as nice but in the long run it is probably the better way to do it.
Here is another "looks good" but may not be better in terms of function.... "extra straight line" mounting of components in P2P-style amps :wink: .
From a mojave amp:
http://www.mojaveampworks.com/1Amplifie ... layout.jpg
It looks beautiful but will actually cause more stress on solderpoints (during heat and cool down) than with less straight and tidy connected component legs.
MoreCowbell
He's a Purdue graduated engineer that decided to build a few pedals :)
