Digitech PDS1700 trimpots
- lolbou
I guess that having the schematic is a good thing to start with... Finding it is not always easy, but if you feel confident about it, you can do it yourself by looking at the pcb...
If your effect is only analog, then some of the trimpots will, I think, tweak the gain of the unit, the feedback of the BBD device, the clock adjustment, and the balance between wet and dry...
If it uses a digital component, it might be as well, or not...
Did you try to get teh schematics from Digitech?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- lolbou
Are the components quite common in it or is there any E.T. stuff?
If the pcb is one-sided and the ICs quite common, you should be able to "read" the schem...
If not, it might be hard...
Anyway, if it works, don't touch it (in an analog or digital device)... Someone tweaked the '79 Electric Mistress I found the other day, and I'm still trying to fix it hoping no IC is damaged...
