solder pads-stupid question
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
this is stupid question, but ...... :?
how do they make those places ((where you solder)...solder pads on PCB) not covered with lacquer....?
it is stupid question, but what is the answer???
thanks
boris
BennyBoop
Post by BennyBoop »
They remove the lacquer after the etching process.
NO :slap: :slap: :slap:
Actually, most professional PCB design programs provide for as many as 12 layers for a single PCB design - for example - a bottom layer, a top layer, a silkscreen layer, a solder layer etc.
The pads are usually inserted as multi layer elements by the design process - so a solder mask layer is very easy to implement. For the solder mask or the laquer layer the pads become holes in the lacquer coating. I do not manufacture commercial PCBs, but I would guess that the lacquer layer (including the pad holes) is sprayed onto the solder side of the board immediately after the etching process and before the solder side is tinned.
I use common spray lacquer and it can be soldered over. I just spray the whole solder side and it's fine. In fact, I have read that the lacquer acts as a mild flux, and from my results I believe that this is the case. This isn't professional solder mask stuff, it's just common lacquer I get at the hardware store. It does work well as a mask too, and it does an excellent job of protecting the copper.
borislavgajic
I was thinking in that direction also........and question is how to make solder pads protected from being sprayed? little drop of candle wax first, and then spray it over and then remove wax.... :arrow: clean pad :?:
boris
now I spray all over pcb after soldering...so all is under lacquer :blackeye
after all it was stupid question :wink:
Me too! :blackeye :blackeye
borislavgajic
Mister soulsonic :thumbsup if You are doing it.........I'm gonna do it too :blackeye :blackeye :thumbsup
P.S.
what do you say about that wiggler? is it worth cloning? is sound good?
boris
BennyBoop
Post by BennyBoop »
BennyBoop wrote:They remove the lacquer after the etching process.
Oh, saw that I missed the questionmark, haha.
Thank's for the description Baja. :wink:
