Tube bias meter
Nikifena
Been thanked: 39 times
Post by Nikifena »
Hi guys, I make a small meter to bias tube amplifiers
Here is a schematics and pictures how I make this meter:
And the ready to use tester :)
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
Nice work Niki!
That would be so useful for building SE amps! Stops you having to fiddle around inside the little bu**ers, which is always a danger for me as I'm either 1) Heavy Handed or 2) Drunk/Hung Over... I imagine it would be a great safety upgrade for me!
I am Klon.
gnognofasciani
Been thanked: 11 times
Post by gnognofasciani »
That's awesome!
Search button is your friend
drumslinger
Post by drumslinger »
Very nice. Nice clean work. Thanks for the Illustration Niki.
iwantmypie
Post by iwantmypie »
how much for one :D
Use boost pedals
noelgrassy
Post by noelgrassy »
^ Yeah! How much for one?
Thanks for posting this. It's a really tidy build that most band's techs should be throwing in their toolbag.
very cool.
what gauge did you use for the blue wire?
Nikifena
Post by Nikifena »
Thanks guys ;) :thumbsup
I don't sell this. I make only one for me.
I give the idea how to make bias meter at home. Just that.
This cost less than 10Eu - in Bulgaria and about 4-5 hours of work and thinking how to do that.
The "blue wires" are pins from 1n4007 diodes - about 1mm.
ok, cool. i thought they looked just like the leads from the resistor. then what did you use for the blue spacers? are they made out of plastic?
Nikifena
Post by Nikifena »
I make a blue spacers from a multi wire standart cable. I cut the isolation of a cable and insert into the diode pins ;)
I think, that this is not necessary, but I did it - it looks better ;)
