CAE Sound preamp CB2 - The one in the Warren Haynes Les Paul [traced]
- JimiB
I saw Gov't Mule the other night and Warren sounded better than ever. He was using les gain and sounded killer! I did notice the little toggle by his vol/tone knobs but didnt know what it was. Then I happend on the video of his new built in buffer/preamp
Anybody have any info on this unit?
This is a replica of what John Cutler developed for Jerry Garcia's guitars.
http://www.caesound.com/cgi-bin/cae/info?bufPreamp
Huge pic of it here
http://www.caesound.com/cb2_spec_7.pdf
Found these pics on Ebay claiming to be that unit
Huge pic of it here
- Back.jpg (24.58 KiB) Viewed 2831 times
- Warren Haynes-Jerry Garcia Preamp.jpg (14.62 KiB) Viewed 2909 times
- JimiB
Another Pic from the CAE website
CB2 Specs
Frequency response 40Hz to 10K Hz
Output Z = 600 Ohms
Input Z = 475K Ohms
Phase = 180’ Inverting
Power Requirement = 9VDC Duracell MN1604
Current Drain = 5mA
Size in inches = 2 _W X 1 1/2L X 3/4" Tall
Weight = 18grams
Gain = 1X (Unity)
CB2 Specs
Output Z = 600 Ohms
Input Z = 475K Ohms
Current Drain = 5mA
Weight = 18grams
Gain = 1X (Unity)
- prod_im_CB2.jpg (6.11 KiB) Viewed 4221 times
- analogguru
Nobody knows why:
1.) there is only unity gain
2.) the signal inverted
3.) the chip is sanded and there is a current consumption of 5mA
ad 1.) if there would be a gain of 10 (and if desired attenuated at the end of the cable by the factor of 10) the performance of hum (and other noise) introduced by the (long) cable would be better.
ad 2.) the same specs can be achieved in a non-inverting configuration too.
ad 3.) since there is unity-gain the noise of the op-amp does not play an important role (the noise of the resistors are higher) so a TL 061 could be used, resulting in a power consumption of 200µA only, thus giving a 25 times !!! longer battery life.
- unbeliever
The .pdf says 'The goal was to produce a preamp that would boost the signal...', so the unity gain is a bit odd. Maybe it was done this way to avoid a difference in behaviour (with respect to levels, or overdriving inputs on pedals) as compared to a non-buffered signal?
- sugarinthegourd
I've been thinking about installing a SHO circuit onboard in a guitar. Would want to get rid of the crackle on the knob though, as the whole point of putting it on the guitar would be having the gain boost at my fingertips.
- Lovepedal Detective
Warren isn't using this as a boost or preamp. He is using it as a buffer to prevent high end loss when rolling down his guitars volume control. It is similar to the way a "treble bleed" cap works on a guitar. The reason it is on a switch is because sometimes he does want the roll off, some times he doesn't.
I really like the tone of a humbucker guitar when it is not loaded by cable capacitance, it makes the guitar tone much more lively and sparkling. I found this using a wireless unit (Samson Airline) that plugs directly into the guitar jack. So putting a preamp in the guitar at unity gain makes a lot of sense, although flipping the phase doesn't. My Strat can get a little bright sounding through the wireless unit though, but that is what tone controls are for.
I wouldn't recommend putting a SHO in a guitar as it colors the tone too much, unless that is the tone you are looking for.
- JimiB
does this mean the phase would flip when he flips the switch?
Whatever difference this preamp/buffer made I could hear in his playing - thats what made me excited about - he didnt need as much gain which really let his playing shine.
- soulsonic
Oh yes, that's a good point! But like phase switches on other guitars, it only really makes a big sound change if it's on one of the pickups and both are on at once.JimiB wrote:does this mean the phase would flip when he flips the switch?
- RnFR
i'm sure that would drive the FOH guy crazy- you get his guitar balanced against the rhythm player's, and then he goes switching it in and out of phase the whole show! i know i wouldn't want to have to deal with that. especially playing in smaller rooms where it the amp and PA sounds could get switched in and out of phase. that's just bad design if you ask me. and don't even get me started about recording...
- sugarinthegourd
I don't see how that could have any effect. Out of phase with respect to what? Move your ear a millimeter further from the speaker and the sound will go "out of phase."RnFR wrote:i'm sure that would drive the FOH guy crazy- you get his guitar balanced against the rhythm player's, and then he goes switching it in and out of phase the whole show! i know i wouldn't want to have to deal with that. especially playing in smaller rooms where it the amp and PA sounds could get switched in and out of phase. that's just bad design if you ask me. and don't even get me started about recording...
- Bernardduur
You don't a phase change except when it is compared to something else!sugarinthegourd wrote:I don't see how that could have any effect. Out of phase with respect to what? Move your ear a millimeter further from the speaker and the sound will go "out of phase."RnFR wrote:i'm sure that would drive the FOH guy crazy- you get his guitar balanced against the rhythm player's, and then he goes switching it in and out of phase the whole show! i know i wouldn't want to have to deal with that. especially playing in smaller rooms where it the amp and PA sounds could get switched in and out of phase. that's just bad design if you ask me. and don't even get me started about recording...
- RnFR
i thought they had two guitars. sorry don't listen to hippy rock!
seriously, i don't know what the fuck i was talking about with that pa comment above- one too many "jazz cigarettes" maybe.
but i would try to minimize phase changes as much as possible. and phase issues between two similar guitar tones could come up. i deal with phasing issues all the time, and wouldn't want to compound the problem. i could imagine overdubbing the boosted signal over a nonboosted track. you'd be pretty screwed then- especially if it as "transparent" as they say it is. but then again, with all the inverting amplifiers we use making pedals who knows.
- RnFR
after thinking about this a bit more, it would probably be a good idea to try to keep "clean" type boosters in phase whenever possible. if the tone is going to change anyways- who cares.
i thought they had two guitars. sorry don't listen to hippy rock!![]()
- Ronsonic
I'm guessing TL062 for low current draw, guitar sees a very high Z at the noninverting input of one opamp which drives an inverting opamp for the low Z output. That could give us the specs we see here.
My Pedals, Products, Services and DIY Blog: http://ronbalesfx.blogspot.com/
- analogguru
1.) It´s a single op-amp (+ on pin 7) so it would be a TL 061Ronsonic wrote:I'm guessing TL062 for low current draw, guitar sees a very high Z at the noninverting input of one opamp which drives an inverting opamp for the low Z output. That could give us the specs we see here.
2.) a TL061 doesn´t have 5mA current consumption (only 200µA) as written in the description.
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
probably a TL071 - 5ma current draw or similar
