Fodera, Sadowsky, aguilar, and other bass preamps
hello Immo :)
Sorry about the dark grey - I was trying to get the best resolution artwork for under the 1M posting limit :wink:
I think I tried posting the gerber files as .txt (and many other formats)
I will try again and see.
Steve
OKAY
I tried to upload the gerber files as *.txt and got the message that txt files are NOT allowed.
I give up :evil:
the gif file as requested :wink:
lietuvis
Has thanked: 95 times
Been thanked: 83 times
Post by lietuvis »
bajaman wrote:OKAY
I give up :evil:
Hi Bajaman you can try to upload a zip file, previously I was able to do so. right click on mouse then compress file or a few files on mac os, something similar would be in windows, name it whatever you want and upload if its under allowed size to forum
Baja three band jazz bass preamp gerber files.zip
(20.71 KiB) Downloaded 483 times
Okay - thanks for the suggestion lietuvis :thumbsup
Here is a zip file containing the gerber files for both SMD and through hole boards :wink:
They are both together, but if you know how to use gerber files you should now how to edit them to suit your chosen format :)
RE: BAJA three band active bass preamp:
Here is a more friendly component value schematic for the through hole board layout.
I very much doubt that you would hear any difference to the 051112 schematic previously posted in this thread, but I am sure you will find the components much easier to find.
You can use either the LF442 or TL062 (both are equivalent bifet input low current drain op amps for extended battery life :wink: )
I just finished populating a through hole board with these component values - it will be a wee while before I can install it in the Jazz bass I am putting together though - I have to make the body first :lol: I already have the neck, machine heads, pickguard, control plate and pick ups (neodymium button magnet and steel pole piece design) sorted, so won't be too long before I can play it :wink:
Baja three band active bass preamp through hole board 171112 .gif (70.47 KiB) Viewed 5934 times
here is a quick scan of the completed PCB :wink:
missing capacitor (470n) is smd on rear of board :)
NO noisy carbon comp capacitors fitted :roll:
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
this is cool,what are the center frequencies for each band?
I'd like to know if there is an existing board with fixed B and T and parametric mids all in one,otherwise i could try to design it myself.
That with a 20dB boost would be the end of all pres.
look back in the thread :wink: - see the graphs :roll:
HINT: halfway down page 5 :secret:
Way too much boost :slap:
alexradium
ok thank you
Duckman
Has thanked: 320 times
Post by Duckman »
Looks really beautiful! Baja, you´re a master!
rcustoms
Has thanked: 363 times
Been thanked: 518 times
Post by rcustoms »
my contribution
a complete project on the yamaha's type preamplifier founded in many brands,who cloned this circuit
YAMAHA TMB.pdf
complete project
(1.91 MiB) Downloaded 707 times
I hope you enjoy
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Post by rcustoms »
another ,peavey cirrus bass
cirrus bass.bmp (897.25 KiB) Viewed 5857 times
cirrus bass.bmp2.bmp (898.3 KiB) Viewed 5857 times
ezugaru
Has thanked: 37 times
Post by ezugaru »
bajaman wrote:RE: BAJA three band active bass preamp:
Hi bajaman, there is no C12 right? it jumps from C11 to C13, greethings!
You are not dumb if you are a good person, is just that dumb people don't recognize the good things.
correct :wink:
B3ar
Has thanked: 30 times
Post by B3ar »
Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
The external connections are on the PDF.
DeArmond_Pilot_Pro_Basses.pdf
Dearmond Pilot external wiring
(109.33 KiB) Downloaded 376 times
Dearmond Pilot back
Dearmond Pilot back
Dearmond Pilot front
alexradium
[quotes="B3ar"]Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
The external connections are on the PDF.[/quote]
This is the same Board on the Cort gb75 i had
I did tracing and its all based on gyrators
B3ar
Post by B3ar »
alexradium wrote:[quotes="B3ar"]Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
I did tracing and its all based on gyrators[/quote]
You know, if I had thought about that, I might have started to look at Cort as it's Korean made. Thanks for saving me the effort on this.
rcustoms
Post by rcustoms »
B3ar wrote:Hidden tracks on SMD are a pain. And it's always a little odd to trace a partially populated board. SoI'm pretty much giving up on this, the active circuit from my 4 string Dearmond Pilot pro. I'm just gonna assume standard BF Fender-style TMB unless I get a bug to follow through on the trace.
ok folks ,let me help ,i been working on this version of the circuit and has two additional trimmers and a little few more components.i trace everything and this is my work,not checked, but I think together we can finish.
PRE CURBOW AND PILOT.pdf
(95.79 KiB) Downloaded 482 times
I made this PCB with no SMD components
PRE CURBOW AND PILOT 2.pdf
(184.02 KiB) Downloaded 435 times
rcustoms
Post by rcustoms »
wiring and trimmers func.
