Fodera, Sadowsky, aguilar, and other bass preamps
Brink
Been thanked: 18 times
Post by Brink »
Someone has come forward and offered to trace the Sadowsky preamp/DI. I just mailed the pedal off a few minutes ago.
Silent Fly
Has thanked: 27 times
Been thanked: 47 times
Post by Silent Fly »
Brink wrote:Someone has come forward and offered to trace the Sadowsky preamp/DI. I just mailed the pedal off a few minutes ago.
Excellent! Thanks :thumbsup
quaternotetriplet
Has thanked: 10 times
Post by quaternotetriplet »
Nice.
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
I would love a pcb layout gif to make one of these. :D
Skyline FX 2013
chicago_mike
how would I take the green out to make this apcb printable file?
I am thinking of making my own class d bass amp and using something like this as the pre.
Skyline FX 2013
lietuvis
Has thanked: 95 times
Been thanked: 83 times
Post by lietuvis »
chicago_mike wrote:how would I take the green out to make this apcb printable file?
Hi if you are talking about this one I've posted as a ampeg and swr hibrid bass preamp there is diptrace pcb file.if you have any questions pm me or email me litvanas at googlemail.com
PREAMP.dip.zip
(8.16 KiB) Downloaded 912 times
chicago_mike
:hug:
Skyline FX 2013
quaternotetriplet
:shock:
chicago_mike
yes were all tree huggin lovie dovie hippies here... :P
Skyline FX 2013
quaternotetriplet
:hug: yeah can i join. LOL :applause:
chicago_mike
sure....
umm.... how do I turn youre schematic/layout into a printable layout? I tried the program but eaglecad even gets me, so .... :oops:
IM super interested in building this. :)
Skyline FX 2013
lietuvis
Post by lietuvis »
chicago_mike wrote:sure....
well you have to use diptrace software which is free to use to certain level and can be downloaded from here http://www.diptrace.com/.when it comes to printing you have to tick boxes or untick what layers you want to print for example silk screen is off then only traces will be printed.hapy building and dont forget to tell the results.it's based on Ampeg B2R +SVT-6 PRO EQ section and I took SWR workingmans 15 very front end with aural enchancer instead B2R ultramid.it easy can be modified to have efx send return option or built as only semiparametric EQ with Ampegs or SWR parameters by changing resistor+cap+pot values.
chicago_mike
I saw the export option, but didnt see any format I could really use, well photoshop did recognize one thankfully. :)
Skyline FX 2013
chicago_mike
Nevermind...just made a pdf... :roll:
played around with diptrace..its interesting, but I already goof with eagle and my brain doesnt need more confusion. :cry:
Skyline FX 2013
gena_p1
Has thanked: 23 times
Been thanked: 11 times
Post by gena_p1 »
Brink wrote:...
I've got a Sadowsky Bass Preamp/DI sitting around, in a unmodded and nonworking condition. The board is SMD and ungooped. Tracing this is beyond my abilities, but if someone else wants to do it I'll mail it to them.
Values are unreadable, so here is nothing to trace (and compare to cube 60 bass)
lietuvis
Post by lietuvis »
Hi, got chance to trace Fender Precision Deluxe Lyte MIJ onboard preamp.files are in DIPTRACE software format.the PCB is doublesided :( but schematic is pretty simple so it can be done on single layer board.
fender 3band eq in diptrace.zip
(8.78 KiB) Downloaded 372 times
Silent Fly
lietuvis wrote:Hi, got chance to trace Fender Precision Deluxe Lyte MIJ onboard preamp.files are in DIPTRACE software format.the PCB is doublesided :( but schematic is pretty simple so it can be done on single layer board.
quaternotetriplet
that was nice preamp..
lietuvis
Post by lietuvis »
Here is another interesting bass preamp (has minor errors) with variable low pass filter and switchable Q found on other forum.
jay42
Been thanked: 7 times
Post by jay42 »
I don't have permission to share the Sadowsky preamp schematic, however, I can describe it to the point that you can develop your own. First off, it's a Blackface preamp done with JFets. The tone stack is scaled appropriately...which is to say, the 100K slope resistor becomes a 10K slope resistor and the capacitors go up by a factor of 10. For a built-in, you've got a 500K audio pot for volume up front instead of after the tonestack. 2x 2N5457 You could add a mid-range pot in lieu of the fixed resistor, which is 750 ohms instead the 960 you would expect. I've been told that the Aguilar two-knob built-in is the same circuit, but I can't confirm it.
I sort of think it's ironic that some bassists will say, "I'm all modern here with active electonics and all. I need a flat pre-amp." They're really just playing through a Fender.
