will you send it to me please.jay42 wrote:I don't have permission to share the Sadowsky preamp schematic, however, I can describe it to the point that you can develop your own. First off, it's a Blackface preamp done with JFets. The tone stack is scaled appropriately...which is to say, the 100K slope resistor becomes a 10K slope resistor and the capacitors go up by a factor of 10. For a built-in, you've got a 500K audio pot for volume up front instead of after the tonestack. 2x 2N5457 You could add a mid-range pot in lieu of the fixed resistor, which is 750 ohms instead the 960 you would expect. I've been told that the Aguilar two-knob built-in is the same circuit, but I can't confirm it.
I sort of think it's ironic that some bassists will say, "I'm all modern here with active electonics and all. I need a flat pre-amp." They're really just playing through a Fender.
Fodera, Sadowsky, aguilar, and other bass preamps
- quaternotetriplet
- Silent Fly
Based on the indications supplied. It should be correct:
- lietuvis
Hi all, I've been working on onboard preamp. Tried to achieve few things : low noise, non interactive controls, switchable mid frequency @ 250Hz, 500Hz and 1kHz, small footprint. The circuit itself is nothing new, as a base I used GK RB400 preamp EQ section, then just shrunk to what I needed. Mid frequency is selectable by installing different values on capacitors, where 250Hz=103, 500Hz=472, 1000Hz=222. The treble can also be chosen to different frequency lets say for 7kHz capacitor is 222, for 4kHz-103. Bass is controlled @ 60Hz.
To keep the pcb as small as I can I run wires to pots directly from corresponding pads. all resistors mounted standup, caps standard box type 5mm spacing. I've used mc33178 chips, they quite low noise an low current, tried TL062 but boosting highs had too much hiss.
All work done on DipTrace software.
To me this preamp sounds cleaner, more transparent an not harsh when all controls are up, than stock fender 3band EQ.
So here are the files I worked from, any questions wellcome.
ONBOARD PREAMP SCH PCB.zip- (8.57 KiB) Downloaded 442 times
- roseblood11
This is a great preamp:
http://www.albertkreuzer.com/preamp.htm
For onboard use it should be modified a bit.
-Most (all...) of the switchable options and the clip indicator can be left out
It´s still a bit overkill...
-Instead of symmetrical power supply, a voltage divider could be used. (18V from two batteries will give more than enough headroom)
-the original has a +/-15V power supply. But the JFET´s only see Vref (0V)..+15V (maybe to protect them - 30V would be their maximum rating). With a 18V supply, this could be changed, to increase the headroom.
- andregarcia57
hello how are you?
I'm in need of schematic "Sadowsky Outboard Bass Preamp"
you can send me?
Grateful
andré
you can send me?
Grateful
andré
- Silent Fly
I don't know what you need it for but if you want build one, in theory if you use this schematic and you add a balanced line driver it should be equivalent to the outboard version...andregarcia57 wrote:hello how are you?
you can send me?
Grateful
andré
Thanks Silent Fly!Silent Fly wrote:Based on the indications supplied. It should be correct:
Somehow this reminds me vaguely of the Acoustic 360 tone stack. I don't know why...
Jay42: can you confirm SF's schematic?
Rgdz,
Mark
Thanks.t-mibik wrote:Marsbel, just put the two 1meg resistors to ground unless Vref an it'll be ok
EDIT // you can also remove the 2nd source capacitor for lower distortion, and the 100n cap after the tone stack.
Do I have to change something when I run 18V? I think the Sadowsky outboard preamps run 18V.
Regards,
Mark
Thanks!jay42 wrote:it's accurate.marsbel wrote:Jay42: can you confirm SF's schematic?
I never expected such a simple circuit. I knew it was Fender tone stack derived, and it's not linear at all, but it makes a bass sound so good.
Parts are ordered.
- Brink
- Degoop Doctor
Is that really the way the volume pot is wired? The way I'm used to seeing them would be with lug 3 to input, lug 2 to C4, and 3 to Gnd.Silent Fly wrote:Based on the indications supplied. It should be correct:
- quaternotetriplet
im looking for american deluxe preamp. anyone?
- quaternotetriplet
where can i get center detent pots?
thanks josh
thanks josh
- ezugaru
So for the MID control I just add another 25K Audio pot in place of the 750 ohm resistor?quaternotetriplet wrote:will you send it to me please.jay42 wrote:I don't have permission to share the Sadowsky preamp schematic, however, I can describe it to the point that you can develop your own. First off, it's a Blackface preamp done with JFets. The tone stack is scaled appropriately...which is to say, the 100K slope resistor becomes a 10K slope resistor and the capacitors go up by a factor of 10. For a built-in, you've got a 500K audio pot for volume up front instead of after the tonestack. 2x 2N5457 You could add a mid-range pot in lieu of the fixed resistor, which is 750 ohms instead the 960 you would expect. I've been told that the Aguilar two-knob built-in is the same circuit, but I can't confirm it.
You are not dumb if you are a good person, is just that dumb people don't recognize the good things.
- ezugaru
P.S. for the sadowsky preamp, are the values of C6 (5uF) and C7,C9 (50uF) correct??? they seem hard to find :sezugaru wrote:So for the MID control I just add another 25K Audio pot in place of the 750 ohm resistor?quaternotetriplet wrote:will you send it to me please.jay42 wrote:I don't have permission to share the Sadowsky preamp schematic, however, I can describe it to the point that you can develop your own. First off, it's a Blackface preamp done with JFets. The tone stack is scaled appropriately...which is to say, the 100K slope resistor becomes a 10K slope resistor and the capacitors go up by a factor of 10. For a built-in, you've got a 500K audio pot for volume up front instead of after the tonestack. 2x 2N5457 You could add a mid-range pot in lieu of the fixed resistor, which is 750 ohms instead the 960 you would expect. I've been told that the Aguilar two-knob built-in is the same circuit, but I can't confirm it.
Greetings,
I think you could try 47u and 4u7 without much problems.
Thanks for all info, I just built the "Sadowsky"-preamp (based on Silent Fly's layout, with some modifications). It works great!
Some notes/modifications:
- 2.5n (in tonestack) => 2.2n
- 5u output cap => 4.7u (still electrolytic)
- 750R (tonestack to gnd) => 2k lin pot (mid control)
- Moved the 500k log Level control to between the tonestack and the second amp stage
- Skipped the 300p (second jfet gate to gnd) because I first had a 330n due to a mislabled bag, which resulted in a very noticeable hi cut. Took me a while to debug, as I first suspected the tonestack, but when I found the problem, I just removed it, works fine without.
- I run the preamp on 18V
- Another resource for a very similar preamp can be found here: https://www.diystompboxes.com/smfforum/ ... ic=73173.0
- Built it all on vero
So far so good, it sounded great with my Vox headphone amp. But when I took it to rehersal, and plugged it into my PA Power Amp i use for head (Peavey IPR 1600, drove it with a Sansamp VT Bass before), there was lots of noise and very low output. Some investigation proved the output impedance of this preamp is much too high for my power amp (which takes max 7.5kohm).
So i found a rather simple solution. I built an AMZ super buffer (this one, used OPA2134 for opamps) into the same casing, right before the output jack (so that the buffer is on even if the preamp is bypassed). This was a very good solution. The preamp is now completely noise free, and the output inpedance is so low that you can use this preamp as a headphone amp! The only thing that's missing is balanced DI-out, but I could never fit a DI tranny (or anything else for that matter) into this box.
My Sansamp VT Bass goes into the bottom drawer now
The preamp is the top left one. I didn't put in a footswitch, since it's always on, but there's a bypass switch on the back side, should I want to use it as buffer only:
/Fredde
/Fredde
