Analogman - King of Tone  [traced]
Has thanked: 4410 times
Been thanked: 2139 times
The mystery capacitor in another KOT gut shot
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
do you know how old this pedal is?
Bolsyo
Has thanked: 41 times
Been thanked: 34 times
Post by Bolsyo »
Seiche wrote: 19 Mar 2019, 21:22 pretty sure, yes, which pictures are you referring to and which resistors?
I think they were brown-black-red (1k) and brown-black-yellow (100k), but it's not entirely clear on my pictures and I already flipped the pedal.
Nice find Seiche ! :thumbsup
The 100k gain resistor, while keeping the same pot value on high-gain side, corresponds somewhat with a quote from Analogmans webstite: "It increases the DRIVE knob setting by a few numbers, in any mode. It moves the ENTIRE range higher".
According to this gutshot from madbean, the 3rd band on a stock gain side seems red (1k) to me, and not 10k as was earlier assumed:
(The carbon FILM resistor going into lug 1 (J27) on the drive pot):
Seiche wrote: 23 May 2020, 12:45 do you know how old this pedal is?
Not yet, scored it on facebook, I'm asking the owner of the pedal.
Bolsyo wrote: 23 May 2020, 13:08
Seiche wrote: 19 Mar 2019, 21:22 I think they were brown-black-red (1k) and brown-black-yellow (100k), but it's not entirely clear on my pictures and I already flipped the pedal.
Thanks for that old picture -- anything that is important to the discussion in this section, please please attach it to the post. External links always go dead.
Here's a close-up of the little rascal (from the same madbean unit)
Gain resistor of 1k in orginal KoT traced
Screen Shot 2020-05-23 at 17.10.28.png (220.05 KiB) Viewed 5935 times
Bolsyo
Post by Bolsyo »
This gutshot was posted of a high gain side. Look at the resistor going into lug 1 on the drive pot here. According to the new tracing, it's should be a 100k (brown-black-YELLOW), but here it is a 1k (brown-black-RED). Now look closely on the red band... It's clearly painted on there, and you can even see the yellow under the lower edge of the red stripe :lol: Never take the color coding for granted :D
Boba7
Has thanked: 25 times
Been thanked: 13 times
Post by Boba7 »
Bolsyo wrote: 23 May 2020, 17:11 This gutshot was posted of a high gain side. Look at the resistor going into lug 1 on the drive pot here. According to the new tracing, it's should be a 100k (brown-black-YELLOW), but here it is a 1k (brown-black-RED). Now look closely on the red band... It's clearly painted on there, and you can even see the yellow under the lower edge of the red stripe :lol: Never take the color coding for granted :D
Haha that’s great, thanks! So it’s official, low gain is 1k and high 100k. Nice.
Boba7
Post by Boba7 »
Seiche wrote: 07 Jul 2018, 13:39 - the input cap is 22n on both sides
- instead of 1s1588, this uses 1n914
- output cap of the high-gain red side has an "H" painted on it, but is the same value 105 as on the yellow side.
- the feedback loop cap on the yellow side ist a weird value. 505? The red side has the usual 101=100pF.
I haven't verified all of the resistors.
So on the Pedalpcb forums, someone posted another odd value for C22 on the yellow side: 750pf.
See here: https://forum.pedalpcb.com/threads/prin ... post-27138
What do you guys think?
King of Tone C22 Yellow side
Boba7
Post by Boba7 »
modman wrote: 23 May 2020, 15:14
If you still have your unit, could you verify if the diodes in the feedback loop are connected like that (see attachment)?
Thanks a lot!
KOT diodes
KOT diodes
Capture d’écran 2020-06-19 à 13.38.38.png (11.53 KiB) Viewed 5511 times
Boba7 wrote: 19 Jun 2020, 11:40If you still have your unit, could you verify if the diodes in the feedback loop are connected like that (see attachment)?
Thanks a lot!
viewtopic.php?f=7&t=382&p=271493#p271493
here's the correct schematic - what makes you think the diodes are interlinked?
Boba7
Post by Boba7 »
modman wrote: 19 Jun 2020, 11:50
Thanks a lot!
Same thread on the Pedalpcb forums, the guy has traced his KOT and found the diodes are interlinked.
sprentiss
Been thanked: 12 times
Post by sprentiss »
Hey guys, that's my pedal that Boba7 posted. Both sides use the same cap in the feedback loop, marked 751. I've measured it in circuit and it's 750pf but my meter isn't the best.
I'll try and get you guys an under shot of the PCB so you can see the diodes being linked. May have traced that bit wrong myself but I'm pretty sure that's how they're set up.
sprentiss
Post by sprentiss »
Ok. Just double checked the diodes with my continuity test and confirmed that they aren't linked in the middle that's my bad. Though it shouldn't make a difference.
sprentiss wrote: 20 Jun 2020, 01:43 Ok. Just double checked the diodes with my continuity test and confirmed that they aren't linked in the middle that's my bad. Though it shouldn't make a difference.
Thanks so much for reporting back.
Anybody tracing a unit, please make pictures and if there is a serial, mention it on the schematic. There may be differences betweens different hand built units, improvements or just mistakes by organic Japanese vegetable farmers!
sprentiss
Post by sprentiss »
Here's my traced schematic with the serial number and build date noted.
rtcustom
Been thanked: 22 times
Post by rtcustom »
So, due to the increase in the value of the capacitor, the new versions have less noise than the older versions?
sprentiss
Post by sprentiss »
rtcustom wrote: 20 Jun 2020, 20:11 So, due to the increase in the value of the capacitor, the new versions have less noise than the older versions?
I don't know if it's because of that cap change but mine is dead quiet even at high gain settings.
rtcustom
Post by rtcustom »
i think that cap reduce noise level of the unit. The increase is significant, primal pedals 100pf, latest 750pf. Analogman could increase the value of that capacitor to 1nF and would not drastically cut high. ;)
It's just a game! :)
Boba7
Post by Boba7 »
rtcustom wrote: 20 Jun 2020, 21:26 i think that cap reduce noise level of the unit. The increase is significant, primal pedals 100pf, latest 750pf. Analogman could increase the value of that capacitor to 1nF and would not drastically cut high. ;)
Just a game, yes, for sure! :)
By the way, is there a way to calculate the low pass frequency in this kind of circuit?
rtcustom
Post by rtcustom »
Boba7 wrote: 21 Jun 2020, 10:11 Just a game, yes, for sure! :)
I don't have that much knowledge, although I believe that someone with a better knowledge of matter can define it mathematically!
FiveseveN
Has thanked: 215 times
Been thanked: 116 times
Post by FiveseveN »
The formula is fc = 1/(2πRC) as usual, where R is the gain pot + the 1K or 100K "high gain" resistor. You can use a calculator like electricdruid's.
