Switch battery leads instead of neg. ground wiring?
Cheese Bag
Post by Cheese Bag »
is this ok to do with pnp transistors? Any drawbacks? Thanks.
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
If the pedal is using ICs (especially CMOS ones), it might be a problem...
Regarding to transistors, if you're building a fuzz face, try this: http://www.tonepad.com/getFile.asp?id=82, and don't bother with the ICs as there aren't any in it. :)
You'll see that there's a trick consisting of a jumper set to choose polarity... Maybe you should get inspuiration from that!
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
