Thanks Ringworm, I've been digging through some stuff and intended on re-posting your pics today but you already did it.
The most complete and accurate account of a schematic is this one, with the addition of the BC549C transistor which you can see from Ringworm's pics. The BC549C is consistent with builds from the UK.
The thing to note is the base-collector resistor is 3M3. The schematic with the resistor at 5M7 and the 2N5088 transistor does not represent the pedal. You can see the 3M3 resistor on the Korean board. In Ringworms pics it's hard to tell if it's 2M2 or 3M3.
The 5M7 value could be 4M7 or 2M7. However, I've seen one board with 2M7 so I'd go with that as an alternative build. On the 2M7 unit the 6n8 cap might be 4n7.
There's not a lot of info on these unit. As far as I could see there's a big dip in info on Colorsound products between mid 80's and 1994. At which point Macaris started to sell "ReIssues". From what I can see "ReIssues" didn't always means clones. Dick Denney was somehow involved in some of the products in this era. He apparently designed the inductorless wah so I assumed the inductorless wah appear as a result of this work.
At the same time the Colorsound inductored wah seemed to have disappeared in the dip between mid 80's and 1994.
