It is definitely very loud.
Soul Sonic - Crackle NOT Okay! [documentation]
- soulsonic
Thanks! I'm glad you guys are diggin' it!
- fosnal1950
Couldn't you just change R4 into a 100K pot to get a bit more control ?It is definitely very loud.
- RnFR
yes, you could always add a master volume control.
- trad3mark
- my favorite amplifier: Vox Valvetronix Series
- Completed builds: Super Hard On
Fuzz Factory
Aenima/Torn's Peaker (2 in 1 box with toggle switch)
Valvecaster Deluxe (Boost before VC)
Proco Rat (Mod to power jack, and input cap changed)
87% PillowStone
87% GlassJaw - Location: Ireland (Dublin/Waterford)
- Been thanked: 1 time
hey soulsonic, thinking of having a go at adapting this into a super duper, and also, use a tube instead of fets. ok if i borrow parts of your schem to give it a bash?
- soulsonic
Sure, but with all those changes it would certainly be hard to tell which parts came from me.trad3mark wrote:hey soulsonic, thinking of having a go at adapting this into a super duper, and also, use a tube instead of fets. ok if i borrow parts of your schem to give it a bash?
One thing about tubes, though - I don't think the SHO-style feedback biasing will work with tubes. This is a biasing style that works with BJT transistors and MOSFETs. Tubes bias in a manner very similar to JFETs, and JFETs do not function in this kind of circuit. I recommend reading up about "Common Cathode" tube stages.
- trad3mark
Fuzz Factory
87% PillowStone
had a little go of it just there. You get a lot less gain than with your crackle not okay. I made a tonne of changes, but as it's still essentially based on yours, i thought it'd be the right thing to do to check with you first.
I then tried it with the normal SHO circuit, and although you get similarly low levels of gain, there's no crackle, which i'm guessing is partly cos of the tubes. I think i'm onto something, but the question now is, keeping it running on 9v, what's going to be the easiest way to get the gain up. I'm guessing if i muck about with the resistor between the +9v and where the drain WAS, then that'd help. Any ideas on other values i could try that would affect gain (in a big way)?
I think it'd work better as a sort of Super Duper Valve in One...
- soulsonic
Are you using an ECC83 type? Maybe try a tube that's intended for lower voltage, like one of the subminis. The only time I've ever gotten a decent sound from a high voltage tube running at low voltage is when it was used as part of an overdrive like in a Tube Driver.
If you want to stick with an ECC8x type, then I highly recommend trying it at higher voltage. You can run a simple transformer setup like EHX uses for their tube series and easily get a usable high voltage supply. Even many of the low voltage submini tubes work much better at voltages higher than 9v. By sticking with 9v, you're putting an insurmountable brick wall limit of how much work you can physically get the tube to do.
- Mr. G.
- my favorite amplifier: Undecided
- Completed builds: 3-loop + tuner out TB loop pedal
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Several LM386 based distortions - Location: Nova Scotia, Canada
- Has thanked: 1 time
- Been thanked: 9 times
Just noticed a post on TGP about the crackle not ok... http://www.thegearpage.net/board/showth ... 978&page=2 post #24
Thought it might be relevant to this thread.
- soulsonic
I saw that a week or two ago. I'm banned from there, or I would have probably replied (which probably would have resulted in me being banned... of course!).Mr. G. wrote:Just noticed a post on TGP about the crackle not ok... http://www.thegearpage.net/board/showth ... 978&page=2 post #24
Clearly Vex has no clue how an opamp works, or the basic concept behind using feedback to control gain.
- earthtonesaudio
I attempted to set Zachary straight in post #38. So far no rebuttal.
- 5thumbs
First off, Mr. Earthtonesaudio, that was an excellent reply to Mr. Vex. Respectful, but firm...well played.
Next, Soulsonic, here is the CNO-SHO v2 I mentioned in the other thread.
Nothing shocking here in the way of additions. This is similar to how I implemented the CNO-SHO v1 in a couple of my designs. I wanted to reduce series resistance (for noise reasons), but I didn't want to go back to the "Crackle Okay" SHO. By adding the op amp buffer before the CNO-SHO v1, I could reduce the size of the pot/resistors used in the CNO voltage divider, but kept the ratio between them the same as Soulsonic's original CNO design. All of this while still enjoying the high input impedance (or higher) of the original SHO via the buffer.
Modding a DS-1? Please read 'Build Your Own DS-1 Distortion'.
"Other than a good first-in-line buffer/booster, using other FX to improve bad clean tone is like gift-wrapping garbage."
- RnFR
does the MOSFET bias up with those small resistors? did you try this?
- soulsonic
yeah, I wonder about that too. When I was experimenting with the SHO stuff, it really seemed like 100k was about as low as is practical.
- 5thumbs
Not yet. 100K series is still better than 1M, but that's still a pretty big resistance (at least for the project I'm trying to squeeze those out of.)RnFR wrote:does the MOSFET bias up with those small resistors? did you try this?
- IvIark
Here's a turret layout for anyone interested:
- 5thumbs
OK, didn't sleep well last night, part due to this friggin' cold I've got today, part due to thinking about CNO-SHO v2 and its return to 100K series resistance in my design.
If the MOSFET won't bias with low series resistance as proposed, then perhaps an op amp-based solution might work? R.G.'s Adjusticator comes to mind, but as he spec'd it, it too has a 100K series resistance before the opamp. However, on at least some single op amps such as the OPA134PA, the data sheet indicates that it might bias with much lower series resistance in front of the inputs. I'm going to have to test this to confirm proper operation, but here's the circuit I'm thinking of.
- 5thumbs
And here's the corrected CNO-SHO v2 schematic, with series resistance and biasing voltage resistors at their 2M2 original value. This iteration has a higher input impedance than CNO-SHO v1, but still has high input series resistance (100K) due to biasing requirements for the MOSFET.
- earthtonesaudio
You may have reduced series resistance, but using 10M to bias the op-amp will likely make even more noise than the original.
The buffer will also present the guitar with a fixed load, so you'll lose the interaction with the FET stage as you increase the gain.
- 5thumbs
I agree. It is the change in the latter that has me more concerned than the former. I think all the iterations as-currently-posted would work, but I'm not convinced we've come any closer to an improved (crackle-free) emulation of the SHO than Soulsonic's original.earthtonesaudio wrote:You may have reduced series resistance, but using 10M to bias the op-amp will likely make even more noise than the original.
The question that the designer will have to answer for themselves might be, "Rank from most to least important the following: 1) Varying MOSFET/Guitar load interaction at different bias points (features of both the original SHO and CNO-SHO v1; 2) Low series resistance; and 3) High input impedance." It appears that you can't have all three, so pick two that are most important and then pick your CNO-SHO topology to match your prioritization.
- Silent Fly
You could try this solution as well:5thumbs wrote:(...) I wanted to reduce series resistance (for noise reasons), but I didn't want to go back to the "Crackle Okay" SHO. By adding the op amp buffer before the CNO-SHO v1, I could reduce the size of the pot/resistors used in the CNO voltage divider, but kept the ratio between them the same as Soulsonic's original CNO design. All of this while still enjoying the high input impedance (or higher) of the original SHO via the buffer.
https://www.freestompboxes.org/viewtopic.php?t=5811
fig.5 in the PDF file should do what you are looking for.
