Vox - V830 Distortion Booster
- sevinisthenumber
I want to just do a simple diode clipping switch on this pedal but there are two sets of diodes on the board (d1+d3)(d2+d4). D2 and D4 are coming right off the middle two legs of the jrc488p (47pf cap in between diodes and ic).
D1 and D3 are going to ground after a resistor on the other side of the board.
Just curious what diodes effect the clipping so I can try some different ones out.
Any help is much appreciated.
- RnFR
you should really post a schematic. without it, it is hard to help you out.
but it sounds as if both sets might be used for clipping. on in a feedback loop, and the other to ground.
- sevinisthenumber
ive looked everywhere but cant find a schematic......
- Dirk_Hendrik
Draw one up and post it.
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
sevinisthenumber wrote:the middle two legs of the jrc488p (47pf cap in between diodes and ic).
If your not able to trace the circuit and draw a schematic yourself, you could provide some pictures like these.
It's either of the two sets, of course, or both. I would cut out all the diodes and start from there adding diodes or LEDs or nothing... on your own risk. No risk in having a look at these threads thoughsevinisthenumber wrote:Just curious what diodes effect the clipping so I can try some different ones out.
Diode Selector on Overdrive
2 vs 4 Diodes
But as this circuit really's not yet available, it would be a great to have pictures or a premilinary schematic. Everybody around here will
- sevinisthenumber
Heres some pictures! (crappy cam phone)
- download4.jpg (26.74 KiB) Viewed 3016 times
- download2.jpg (29.58 KiB) Viewed 3008 times
- download1.jpg (28.42 KiB) Viewed 3010 times
- download.jpg (24.5 KiB) Viewed 3532 times
C.S. Lewis
C.S. Lewis
- sevinisthenumber
- sevinisthenumber
Any body know???
C.S. Lewis
C.S. Lewis
- analogguru
Sharper pictures of the track (solder) side of BOTH pcb´s could be helpful.
- sevinisthenumber
Turns out d1 and d3 effect it drastically while the other two I cant really HEAR A DIFFERENCE.....
C.S. Lewis
C.S. Lewis
- sevinisthenumber
Its a unique sound. I would like to know as well!
C.S. Lewis
C.S. Lewis
- Greg
Is there any way you can take some better photos ?
If you do it'll be traced in no time and you'll have all the info you need to mod it.. and so will everyone else here..
- sevinisthenumber
No problem!! When i took these photos i had to use my phone. Ive gotten a good camera since. I will get them up soon!
C.S. Lewis
C.S. Lewis
- sevinisthenumber
I did a few but i realized i was using the pedal wrong. Its made for boosting an already (post) effect or a saturated amp.
C.S. Lewis
C.S. Lewis
Yeah, I'm afraid these photos leave out the second board (there are two in there). I took this beast apart for the first time last night. Not as complex as a boss pedal or anything similar, so it shouldn't be too tough to figure out. I'm going to recreate the board in Spice or some likewise diagramming app, then post results.
But yeah, this is a nifty creamy distortion pedal, and it seems like it could be really great if you could tame the glassy highs and restore a bit of low end to the signal. In due time...
I just found the schematic. I had to join a German forum to get it. I posted this on another forum discussing the 810 VS the 830
The 810 is a Tube Screamer. The 830 has many differences.
830 has no input buffer. While the 810/TS has one gainstage, and clipping diodes in the feedback loop of that gainstage, the 830 has TWO stages. The first is like the TS/810 stage, with clipping diodes in the feedback loop. The second stage has two dioded from signal to ground after the stage, like an MXR Dist+/DOD 250.
So you have a TS overdrive stage, and an MXR Dist+/DOD 250/Ratt distortion stage after it.
The TS stage has limited gain. Here's the interesting part, the gain control is a dual pot, with one half controlling the gain of the TS stage, and the other half controls the gain of the MXR/250 stage simultaneously.
The tone stage is next. The 810 has an active tone control that mostly adjusts the high end.
The 830 has a gain stage, followed by a Big Muff type tone control. One could mod the tone control the same as a Big Muff control.
In that tone control, at some settings, there is a cut in the midrange. It is far different than the tone control in the 810.
The extra stage, and the fact that the second distortion stage follows the first distortion stage, could cause noise.
One could change the two 4558 op amps to TL072, or some other quieter op amps to lower noise.
The second pair of clipping diodes have no capacitor bypass to lower the high freq's some, as the MXR Dist+ and DOD 250 do. A small cap across D3/D4 could remove the very high end, lowering noise and taming the excessive highs of the pedal some. I will try this on mine.
Vox V830 Schematic
Vox V830 Schematic
