Creation Audio Labs - Holy Fire
WhiteKeyHole
Has thanked: 24 times
Been thanked: 219 times
Post by WhiteKeyHole »
http://tinyurl.com/9uvh6j
"'O', this adjusts the amount of overdrive. As you turn up the knob, wave shaping is applied. This wave shaping was inspired by 1940s analog computer technology ..."
Huh?
moltenmetalburn
Been thanked: 7 times
Post by moltenmetalburn »
sounds pretty damn good (for a vid clip) wonder what the hell they have going on in there?
I just watched the video... jeesh... :roll:
Well, one thing I can say with almost absolute certainty is that the "D" control is a variable resistor in series with some diode clippers to ground. Seems like pretty standard stuff....
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
soulsonic wrote:I just watched the video... jeesh... :roll:
That's what he wants you to think....
I am Klon.
dannybuoy
Post by dannybuoy »
I have one on the way... Will post some guts.
plugzzzz
Post by plugzzzz »
just watch some clips of this pedal... very interesting
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Okay, now we've gone off the deep end.
I'm snipping the off-topic stuff and moving it to the Member's Corner.
Please feel free to continue this discussion in the new thread. This stuff just is not germane to the topic at hand.
Carry on.
cbriere
Been thanked: 9 times
Post by cbriere »
i would like to see the schematics of this one,
any idea what type of circuits is inside?
DavidRavenMoon
my favorite amplifier: Vox AC30 TB, Marshall JCM800.
Has thanked: 15 times
Been thanked: 41 times
Post by DavidRavenMoon »
WhiteKeyHole wrote:http://tinyurl.com/9uvh6j
Huh?
Probably some CMOS hex inverters or gates. The old Craig Anderton tube sound fuzz. ;)
But I have no idea what they are doing. The Redeemer buffer circuit is actually kind of involved, judging from the patent application.
"You give a better performance if you skip the eyes" - Raymond Scott
Coney Island Guitars
cbriere
Post by cbriere »
and it comes with 48VDC power supply :shock:
http://store.boutiquetone.com/index.php ... &c=2000035
Güero 2.0
Been thanked: 24 times
Post by Güero 2.0 »
dannybuoy wrote:I have one on the way... Will post some guts.
Where are the guts??
Grendahl
Post by Grendahl »
There's your quick explanation of controls. I find it very interesting that the indicator changes from yellow to red if you're pushing the pedal's input too hard. This thing is pretty wild!
I agree with Güero 2.0 though... where's the guts?
Resistance is futile...
( if < 1 ohm )
Huh?
do you have a link to the patent app?
squrl
Post by squrl »
Grendahl wrote:Image
gain, overdrive, distortion... don't those all generally mean the same thing? :secret:
Grendahl
Post by Grendahl »
This is the signal path through this thing:
Input -> OD -> Distortion -> High Cut -> Gain -> Output
I'd think of it as a box containing a tube-like preamp, a tubescreamer, a very basic tone control, and a volume circuit in series.
Gain = Volume on this pedal. Unity seems to fall at about 11:30 in the clips I've seen. Adds up to 12db to your output. Their user guide states that this should be seen as an overall volume knob.
Overdrive = The drive you push the distorted signal into the gain circuit with. I'd think of this like a preamp, because it's their "wave shaping" circuitry. It's supposed to shape the wave exactly like what you get when you push a tube amp into OD.
Distortion = Adjusts the amount of clipping you get. It applies a "squaring" to the wave signal after about the 2 o'clock position per their user guide. I'd think of this like a Gain knob.
Hi-Cut = A treble cut of 3db from 20kHz down to 500kHz.
( if < 1 ohm )
spaceace76
Post by spaceace76 »
some photos, not too clear though, and it's SMD
https://s593.photobucket.com/albums/tt1 ... re%20guts/
spaceace76
shit, forgot to mention it's source:
https://www.diystompboxes.com/smfforum/ ... ic=89181.0
damn missing edit button :slap:
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
cbriere wrote:and it comes with 48VDC power supply :shock:
? Suitable for use on Phantom Power maybe?
The poster on DIYSB says there is space for 2 X 9v batteries inside the case which tends to suggest that the circuit does not need 48v. With opamps 30v (+/- 15) is the usual safe max although I seem to recall using some with a working voltage of +/- 18v many years ago.
