Sobbat - DB-1 Drivebreaker
himister
Has thanked: 21 times
Been thanked: 28 times
Post by himister »
ryanuk wrote:Once I finished my schem I will post it on the forum.
RyUK
Bump :wink:
Any progress there mate?
ryanuk
Has thanked: 29 times
Post by ryanuk »
RyUK
Bump :wink:
I've drafted a schem - its on my PC somewhere. However, I was waiting on confirmation of the pot wiring, as I mentioned in my earlier post.
However, my hunch is that the wiring follows that of the DB-1 schem in your project ,which also matches with the tiny pic on the random japanese site.
Therefore I'll finish the schem on this basis and will post it. I'll see if I can knuckle down tommorow night. :thumbsup
Peace, out.
RyUK
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Has someone verified himisters DB-1 layout in the meantime?
ryanuk
Post by ryanuk »
Guys - just an update.
I've now have draft schems for the DB-1 and DB-2.
I know that there is a schem for the DB-1 in an earlier post, but as I was finishing the DB-2 schem I noted some anomolies between the two. Specifcially, the 100K/470R resistors in the bypass loop are in a slightly different config in each design.
To check I verified the DB-1 schem against a pic of the DB1 traces I found on the net. 4 hours (and a HEADACHE) later, I conclude that the DB-1 schem posted earlier is correct. No great results, but I will have the original layout of the DB-1 which I can share!
I just need to draft the DB1 layout and I'll post the whole lot. Tommorow hopefully.
Lastly - the only unknown is the diode in the LED circuit. This was assume to be a 4148, but looking at the configuration I think it must be a zener to clamp the voltage for the LED. 5v maybe?
himister
Post by himister »
Good news Ry! :wink: Can't wait to see results! Thanks for the effort!
:thumbsup
Mbas974
Has thanked: 39 times
Been thanked: 40 times
Post by Mbas974 »
http://hp.jpdo.com/dd003/197/img/8499.jpg
in this version the cap on feedback loop of IC2c is 22nF, in PDF file is 68nF.
which is right ?
Any build report ?
THANKS.
Fastnet
my favorite amplifier: Old AC30's
Completed builds: Run Off Groove Splitter Blend
Kay Fuzztone
Si Fuzzface
Post by Fastnet »
Hi folks,
This thread may be dead in the water but here goes...
Have had a DB-2 for many years and finally managed to pick up a DB-1... Broke the switch on the DB2 soon after I bought it so I expect that the DB-1 will follow the same path....the casing is the strongest part of it... Cottage Industry anyone!!
Will post some pics if anyone has a need....
"After silence, that which comes nearest to expressing the inexpressible is music." Aldous Huxley
or...
"Pog mo thoin!"
