Soul Sonic - Hunny Bunny, sweet overdrive
telecaster
Has thanked: 162 times
Been thanked: 12 times
Post by telecaster »
thanks for the clips, sounds very good. Nice work SS !
KindaFuzzy - Looks like a blue nail polish and nutella sandwich.
Freekish - "Our originality is in the basement. Our business is in the toilet"
Guitarlcarl - I did take offence at being called an idiot by a moron.
Mr. G.
my favorite amplifier: Undecided
Completed builds: 3-loop + tuner out TB loop pedal
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Several LM386 based distortions
Been thanked: 9 times
Post by Mr. G. »
fuckyourmom wrote:
Mr. G. wrote:I tried opening it with Line 6 Edit, but it said that this tone is not compatible with PODxt. Oh well, no big deal.
Great sounding pedal btw!
The patch is for Gearbox. I don't think it works with Line 6 edit because Line 6 edit can't handle the "dual tone" patches that the X3 has. Gearbox will work with the xt and X3.
D'oh! I completely missed that :slap:
plugzzzz
Post by plugzzzz »
i get radio frequency how can i cure that??? and it doesnt sound like a overdrive to me its more of a distortion
SPeter
Been thanked: 80 times
Post by SPeter »
plugzzzz wrote:i get radio frequency how can i cure that??? and it doesnt sound like a overdrive to me its more of a distortion
100 Ohm resistor in series with the input and small cap( 47 pF ) to ground!
Yes, that is a good idea!
But I'm surprised it has the radio interference problem. I've built a couple and neither had any problems like that. It may be an issue of layout or wiring.
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
I've used the 301 at low RF frequencies as a buffer stage between an oscillator and amplifiers. It's one of the best op-amps for RF use! :shock:
stringsthings
Has thanked: 21 times
Been thanked: 7 times
Post by stringsthings »
soulsonic wrote:Here is the overdrive I mentioned in another thread. I call it the Hunny Bunny because it sounds sweet.
Soul Sonic Hunny Bunny
It's a cool little hybrid combo of an opamp driving a MOSFET. I came up with the skeleton of the circuit this past summer, and today I built it up on the breadboard to flesh out some details. It has a great range of drive, from light and crunchy to thick and heavy. At it's highest settings, some people might consider it a distortion, I guess it just depends on how hot your pickups are.
just built this pedal using the component values in the schematic ... it sounds really, really good .... most excellent design, mate ! 8)
Tummy )))
Post by Tummy ))) »
Brink wrote:I also made a vero layout, without any mods. Mine is lacking the protection diode, but a bit simpler of a layout. exactly what changes did you make?
I rather like my practice of reversing the layout and putting huge red circles on to indicate trace cuts.
Do BS170s in layouts like this needs static protection diodes like in SHO-style circuits?
I like this circuit through my amp, but I also tried it through a Vox amp and the amount of high end was painful. It's a good candidate for a tone control.
What is the Vbias?
stringsthings
Tummy ))) wrote: What is the Vbias?
Vbias is a common abbreviation for Bias Voltage ... in most stompbox circuits that run off a 9V battery, Vbias is set to approximately 4.5V ....
Tummy )))
Post by Tummy ))) »
Ok, that was new to me. Thank you for the enlightment :thumbsup
Maybe its a dumb question but could somebody share/make a layout for perfboard?
vvv
Post by vvv »
How can I cure the fizzyness and gating decay on this one? Tried different LM301´s and BS170´s, but no difference. Voltages:
LM301:
1.44 --- 3.4
4.03 --- 8.1
3.36 --- 4
0 --- 1.34
BS170:
D = 4.4
G = 4
S = 1.7
vvv
Post by vvv »
vvv wrote:How can I cure the fizzyness and gating decay on this one? Tried different LM301´s and BS170´s, but no difference. Voltages:
LM301:
1.44 --- 3.4
4.03 --- 8.1
3.36 --- 4
0 --- 1.34
BS170:
D = 4.4
G = 4
S = 1.7
Tested also with TL071 and 741 but that "ugly" distortion is more or less there anyway so it´s not because of the opamp.
marcao_cfh
Has thanked: 38 times
Been thanked: 30 times
Post by marcao_cfh »
Here's mine. It's a etched 1590A. When I was removing the black toner after the etch, I though it looks cool this way, so I keeped it.
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Soundsamples please!
marcao_cfh
I will try to record something in the weekend.
marcao_cfh
Sorry, didn't got to record the soundsample. But there's one at the bottom of Soulsonic's page: http://www.soulsonicfx.com/?page_id=88. Mine sounds very similar, but with more highs. I didn't add the tone pot that's mencioned here at this thread.
koldman
Post by koldman »
My version of this
220pf Compensation Cap, B1k honey pot, trimpot on drain with 2n7000 mosfet, 10k resistor and 4.7nf cap to ground on output to volume pot.
