Dunlop - Octavio
- Alex Frias
I've found .047uF a very high value, so I used .022uF instead. A DPDT toggle to switch in and out that and the other cap, as shown at GGG. But to be honest, I rarely use it anyway, the original sound is much better IMHO.
Alex,
I got a question for you about the gain/boost engine. I've etched and drilled the tonepad pcb, but the Dunlop gain/boost enigne doesn't exactly work with it because there is the additional 22 uF cap and 5k1 resistor. That isn't really a big deal, I guess, because you can wire them off-board and solder onto the leads of the pot or resistors and then to ground, which is what I assume you did. But then there is the issue of the boost pot and the 22 uf cap connected to it. The tonepad schematic puts the boost pot between ground and the cap (100 uF on tonepad schematic, 22 uF on Dunlop spec schematic), but the Dunlop spec schematic puts the 22 uF cap between ground and the boost pot. Does the order of the cap and pot matter? Can the tonepad pcb be used as is by simply replacing the 100 uF cap with a 22 uF cap and the appropriate boost pot?
Thanks,
Dr Jones
Thanks,
Dr Jones
- Alex Frias
I think it works properly as I kept the Tonepad order regarding the pot + cap positions. The Boost control has a very effective action along all the pot's course.
I got this circuit working yesterday morning and I have to say that it is bad ass! The effect is amazing. The octave is more apparent on the top notes, but the bottom notes have the broken synth-like quality that I really like. My thanks to all who have contributed to this thread.
Can anyone tell me if the black lead from the board at TP3 connects to the footswitch? You can see pictures of it at my post on BYOC.
http://www.buildyourownclone.com/board/ ... =9&t=26622
Thanks for any input.
- Bernardduur
I've read the discussion
Must say the unit strikes resembles to the original unit Tyco made it from:
http://wc6w.50webs.com/wc6wvint/pops.html?fr411g.gif
More on it!
Great to see! Great sounding unit!
More on it!
- Volume11
- my favorite amplifier: Silvertone 1484
Sunn 2000s(bass) - Location: Houston TX
- Contact:
If I want to take a crack at using this.... what should the size be when I go to print it? I have both photoshop and illustrator, with minimal knowledge. I've only etched a couple boards, so I am still new to it, but I want to build this pedal really bad. I usually use veroboard, but I want to get more familiar with PCB.sinner wrote:Here is my funky version
- Volume11
- Contact:
This is the image I was trying to show in the previous post...Volume11 wrote:If I want to take a crack at using this.... what should the size be when I go to print it? I have both photoshop and illustrator, with minimal knowledge. I've only etched a couple boards, so I am still new to it, but I want to build this pedal really bad. I usually use veroboard, but I want to get more familiar with PCB.sinner wrote:Here is my funky version
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
Volume11 wrote:This is the image I was trying to show in the previous post...Volume11 wrote:If I want to take a crack at using this.... what should the size be when I go to print it? I have both photoshop and illustrator, with minimal knowledge. I've only etched a couple boards, so I am still new to it, but I want to build this pedal really bad. I usually use veroboard, but I want to get more familiar with PCB.sinner wrote:Here is my funky version
Can't help mate, I lost all my data after OS crash
- dai h.
it's a good idea to have back ups(even multiple). Today even big 1.5-2TB drives are pretty affordable, and (probably?) you won't need anything that big for effects stuff. I try to back up regularly after losing a couple HDs simultaneously. (That was definitely not a good feeling.)
I would print it, then place the transformer on the paper where it goes and see if it needs to be shrunk or expanded.Volume11 wrote:If I want to take a crack at using this.... what should the size be when I go to print it? I have both photoshop and illustrator, with minimal knowledge. I've only etched a couple boards, so I am still new to it, but I want to build this pedal really bad. I usually use veroboard, but I want to get more familiar with PCB.sinner wrote:Here is my funky version
By the way, I don't think that is the most recent layout. Look at the next post down from where you got that one.
An update, I spoke to someone from Tycobrahe Sound and he told me the transformer is:ddr wrote:Hi Folks,
Can you tell me the orientation of the transformer? In the analogguru and fuzzcentral schematics the side of the transformer marked primary is toward the diodes and output. Is this correct?
Thanks,
Dan
So, I reversed the transformer I am using so that the secondary is toward the diodes. I think it sounds better now, but that just may be because I no longer need to have the intensity at zero (which was the case when I had the transformer the other way around).The primary was 1.2K, the secondary 600 CT -- 2:1 impedance ratio, 1.4:1 turns ratio with the low impedance side connected to the diodes.
The frequency response was fairly flat 40-20K at around 10 dBm.
The adjustment of the Boost knob is fairly touchy. And then it needs to be "played". The input level is also quite important. Properly tweaked it should just be on the threshold of sustaining.
Regarding the Dunlop, it already has the transformer facing properly, so if you are using the schematic posted in this thread you are fine.
- sinner
- sinner
does the values are correct? R3 looks more like 1k8 to me...Alex Frias wrote:No, I think our friend RnFR is just a bit confused by so many Octavias, as Dunlop promotes it as a Mr Hendrix original.
I made the cap exchange and some mid bass emerged, but nothing that big...
The only thing I really can't understand is the gain pot wiring. And to be honest, although I realy liked the resulting sound, I found the project using the standard Tycho scheme (with 22uF, not 100uF) it has lots of gain even with the pot on its minimun position. So I think Dunlop used a little trick to put it down a bit more...
Let's try to figure out:
- sinner
vero on the way. Can't promised to be added today
- sinner
Radial caps are gay!
