Behringer VM1 Vintage Time Machine
Some more frequency responses.
The dry signal as it arrives after the compressor, just before the anti alias filter and the BBD section for the Deluxe memory man:
(Level and mix is set for unity gain, feedback is at 50%) Same thing but for the VM1:
The VM1 delivers a much more scooped dry signal to the bbd section. The main 'culprit' is that small 22k bottom resistor (compared to 100k in the DMM) in the voltage divider after the first opamp. Another thing to note is that, for the feedback pot, because of its large size (50k vs 10k in the DMM), its position affects the frequency response quite a bit.
In the DMM the feedback pot is 10k, which is 'insignificant' compared to the 100k voltage divider resistors, so the postion of the feedback pot has little to no effect on the frequency response.
Here's the frequency response for the VM1 with the feedback pot at 0% or 100%¨, giving an even more scooped dry signal: In the Boss DM2 or 3, from which the feedback path was copied, the small 20k resistor made sense because they use a different way of summing dry and delay signal for the feedback.
The DMM uses the same passive mixer for the feedback as it does for the output mix, but with two 100k resistors instead of the 10k pot at the output.
The DM2/3 uses an active inverting, summing opamp mixer and it actually uses the internal opamp of the compressor for this. It has a 20k input resistor (R3 at pin 6) and by connecting the feedback signal through a 20k resistor to pin 6 you get a 50/50 suming.
But combining the 100k resistor of the DMM with the 20k resistor of the DM2/3 makes little sense.
Compressor internals (pin 3 is 20k, Boss connects feedback signal through 20k to pin 5): Because the 3205 bbd chips have less headroom and worse frequency response for higher frequencies than the 3005, this 'mistake' kinda works out in the end. The VM1, because of the scoop, sends less signal to the BDD and has a pretty big pre-emphasis on the highs.
But for now we've only looked at the 'mistake' from the dry signal perspective. Next post is about how it affects the delay signal.
Frequency reponse of the delay / feedback signal. Level and mix set for unity gain, feedback at 50%.
In real life the signal coming out of the bbd section has been filtered by the anti-alias filter and the reconstruction filter, but to see the effect of the differences between the DMM and VM1 feedback loop I'm using a FRFR input signal.
DMM: ( - 3dB at 1kHz) VM1: ( + 3db at 1kHz) The DMM has an extra LP filter, right before the feedback pot.
The VM1 is flatter and has stronger repeats in the feedback. It should oscillate earlier on the dial than the DMM.
The VM1 has a softer first repeat but relatively stronger later repeats.
From the plot you'd expect much brighter repeats on the VM1, but in a later post you'll see that in the VM1 the signal looses more highs along the way(in the filters, bbd's, make up gain etc) than the DMM and will eventually have less highs than the DMM.
Once again, you could say that the 'incorrect' 22k and 100n in the feedback loop kinda works out in the end.
Replacing the 22k with a 100k pot and the 100n with a switch to various caps, really lets you shape the repeats both decay-wise as frequency wise.
22k and 100n is better for faux reverb
100k and 22n is better for distinct repeats.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 69 times
- Been thanked: 65 times
- Contact:
Thanks a lot, j_flanders !
That's amazing work in analysis, error-finding and circuit improvement.
I'm proud that 10 years later, this thread still exists and finds some use.
Here is a new version of the schematic, including fixes for the errors you've found. Let me know if there is still something wrong.
Hmm, that would be a very useful and simple mod. A SPDT switch selecting "bright" or "dark" repeats.j_flanders wrote:Replacing the 22k with a 100k pot and the 100n with a switch to various caps, really lets you shape the repeats both decay-wise as frequency wise.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Contact:
It's just a matter of re-wiring the connectors between the jacks PCB and the footswitch PCB. Referring to the schematic above :
- disconnect X6 pin 1 and X7 pins 3, 4 and 5 : this disconnects the tone-sucking input and the LED control.
- connect X8 pin 1 to X1 pins 3 and 4 : this connects the input to the switch formerly used for the LED, and to the direct bypass path.
- connect X1 pin 5 to X7 pin 3 : this connects back the input to the effect through the "new" switch, therefore only when the effect is engaged. No more tone sucking.
If you are careful, you can remove the crimped terminals from the female connector housings with an pointy tool. Otherwise just cut the wires, tin, put heatshrink, solder, shrink.
To identify the connector pins, note that pin 1 has a square solder pad.
Or a quick search could have given you the answer that is already available for more than 3 years : viewtopic.php?f=11&t=28117
Hi JiM,
Thank you very much for your help, I think I'm starting to get my head around it now. Do I lose the led indication in the process, as was mentioned in the post you linked?
I'm thinking about removing the original footswitch and putting in a replacement 3PDT footswitch wired for true bypass like this:
So I'm guessing I should maybe wire X7 pin 1 to effect send, X7 pin 2 to output, X7 pin 3 to input, X7 pins 4 & 5 to the resistor & led lug, and add a new wire for the ground lug. How about the effect return then, maybe something to do with X6 pins 5 & 6? Or would this be anywhere near correct at all?
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Contact:
Yes, the wiring i've devised yesterday is indeed identical to the previous post. It's only logical.
Nope, this is the output of the effect.
That would work.
The input jack is still connected internally to the input of the effect, resulting in tone-sucking in bypass. You need to break that connexion to achieve true bypass.
The resistors and LED are already on the board, you just need to short those two pins.
This one is intended to complete the LED circuit when on, and to ground the input of the effect when off (as it's disconnected from the input jack).
Those are for the modulation speed (Chorus/Vibrato switch).
Why don't you just draw the true-bypass wiring previously described on two poles of your new switch, and then on the third pole replicate the LED part from SW1A ?
Thanks for the feedback.
So let me try this again:
- disconnect X6 pin 1 and X7 pins 4 & 5
- X7 pin 1 to effect return
- X7 pin 2 to output
- X7 pin 3 to effect send
- X8 pin 1 to input
Then install a new led in series with, for example a 1.8k or a 2k resistor and a new ground wire to the 3DPT switch. Would this work?
- X8 pin 1 to input
- POTL
Hello.
This circuit looks like an attempt to take the best of both worlds (I think Chase Bliss Tonal Recall was able to achieve this).
We all know that DMM has excellent replay quality and built-in modulation. But reps can get overwhelmed.
The boss has a high input impedance, which allows him to work with any effects without problems, does not change the phase of the signal, his repeats are not distorted as much as DMM repeats can be distorted, but he does not have modulation and the quality of the repeats is worse.
At first glance, the diagrams look completely different, but if you look closely, we can find a huge number of general schematic solutions.
Let's compare the circuits.
BOSS DM-2
EHX DMM
1)Scheme input
EHX DMM has an inverting amplifier that can boost and cut the signal. But it has an input impedance of only 100kΩ, which is quite low by today's standards. Plus, it can distort your signal. And the phase will change depending on the pedal mode.
Bypass sound is always in antiphase, in delay mode clear sound in antiphase, repeats in phase.
The DM-2 has an input buffer that gives us about 400 kOhm and the phase does not change depending on the pedal mode.
2) DMM ic1B works like a high pass filter, similar to ic1A but does not change the phase of the signal and the filtering of frequencies is less strong.
3) We can see that the sallena-key filters are active in the DMM, the DM-2 is passive, which allows BOSS not to use op amps before BBD and between BDDs to reduce signal strength.
I'm not sure why DMM made active filters, if you have any ideas, please write.
4) The last stage of the DMM amplification is an inverting summing amplifier, similar to what we have at the output of the DM-2 circuit
In my opinion, the DM-2 is a rethinking of the DMM with the task of removing the flaws of the original circuit.
There were several posts in this thread about how you can change the compander settings and improve the feedback performance for a brighter sound.
however we haven't touched on the filtering, I think it is possible to adapt the DMM filters to the passive variation of the DM-2 just by recalculating the component values a little.
In theory, you can get brighter sound, fewer components, and less noise.
BOSS DM-2
EHX DMM
1)Scheme input
