Sola Sound - Tone Bender Mark I (1965)  [schematic]
vanessa
Post by vanessa »
https://reverb.com/item/2547355-1965-so ... one-bender
I posted this a long time ago, not a lot of interest. To me it was a holy grail find. You can use the Zonk Machine PCB that's floating around with a little rework. Enjoy!
-Van
BTW: 9VDC
call1800ksmyazz
Post by call1800ksmyazz »
Very cool Vanessa. Thanks! :D
RLBJR65
Post by RLBJR65 »
Nice! Must have missed it the first time around.
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
Gracias !
markm
Post by markm »
Thanks Vanessa!
Ummmm.
What's up with the avatar?
Now you're Marie Antonette (sp?!!)?
Wasn't the mona lisa there a moment ago? :?
vanessa
Post by vanessa »
markm wrote: Wasn't the mona lisa there a moment ago? :?
Elizabeth the 1st. I could not shrink down the Mona Lisa to avatar size and make it look good. Funny the original [Mona Lisa] was avatar size out of the gate.
:lol:
JHS
Been thanked: 5 times
Post by JHS »
The 2C382 are very hard to get, if you subs it with other Ge-trannies all values for emitter- and collector-Rs must be recalculated...
I reccomend to use trimpot, but you need the voltages of the original TB1 to adjust the trimpots to the correct values.
JHS
vanessa
Post by vanessa »
From an old post:
Q1 hfe = ?
Q2 hfe = 120
Q3 hfe = 92
I would guess based on others findings of the FZ-1 that Q1 is 50-70 hfe.
I'll add that this thing sounds great with those crap transistors you could never get yourself to throw away. It loves leakage, not off the charts but some leakage for all the Q's and a low value for Q1 really makes this one work.
kagaxdx
Post by kagaxdx »
IMO it's an interesting circuit in some aspects...
That output, is using 2M2 :shock: in series with a 500K :shock: vol pot... :? But then lowering impedance before this there's a 47K to gnd.
I'd like to know why?
I know it could be achieved similar results with like a 47K in series with a 10K vol pot (instead of the values above) and pretty much similar impedance...? :?
I bet it may have an influence to the tone... a 2M2 resistor IN SERIES with a 500K vol pot... :roll:
Someone could try to make me (us) see what's the meaning of this?
Thanks in advance...
Has thanked: 568 times
Hello Kagaxdx
The 2M2 resistor would roll off a lot of the high frequency buzz or scratchyness in this circuit.
ps: a well known high end HiFi stereo amplifier manufacturer used to connect a 75K ohm resistor in series with the CD input socket (one each channel of course) in his top end hybrid Stereo Amplifier. guess what - all the reviewers remarked on it's smooth sounding, less stident, less edgy top end response (more like a vinyl record) - (all the other inputs had NO series resistance).
:wink: :lol:
kagaxdx
Post by kagaxdx »
bajaman wrote:Hello Kagaxdx
:wink: :lol:
Thank you Baja,
Then..... 8) If you take a Fuzz Face a silicon one, you have usually more gain (hfe) and more frequency bandwidth (more treble/piercing highs), we could search for a low HFE silicon transistor (or piggback) and for the different high end response use this sort of "soothness"? :wink:
Take the output straight from Q2 colector and conect to a 470K resistor in series with a 100K vol pot... :idea:
MoreCowbell
:wink: :lol:
Thank you Baja,
Ive done some similar experiments, and had mixed results. To be honest, the old "cap to ground" seemed to work better for me, as it retained more of the dynamic properties of the circuit.
kagaxdx
Post by kagaxdx »
Thank you Morecowbell, thats good to hear from someone that had previosly tried that.
That's the good thing: We always keep on searching ways to improve tone 8)
MoreCowbell
kagaxdx wrote:Thank you Morecowbell, thats good to hear from someone that had previosly tried that.
No problem.
Honestly, if I were building a MKI, I'd probably eliminate the 2M2 resistor and use a cap to ground, somewhere between 470pF and .001uF.
alnico
Post by alnico »
There is a resistor missing on the schematic. It should have a 33K from the wiper of the Attack pot to ground.
vanessa
Post by vanessa »
alnico wrote:There is a resistor missing on the schematic. It should have a 33K from the wiper of the Attack pot to ground.
Do you have one? How do you know?
:lol:
This maybe true for the Maestro Fuzztone. If it would be true for the Mk I, then somebody must have stolen it from this unit:
http://82.110.105.12/stompboxes.co.uk/i ... oooiol.JPG
but what I can see is, that in reality R3 is not 470k - it is 180k, especially when I look at it from a different angle - like this:
vanessa
Post by vanessa »
analogguru wrote: but what I can see is, that in realitiy R3 is not 470k - it is 180k, especially when I look at it from a different angle - like this:
Good catch AG.
analogguru wrote: This maybe true for the Maestro Fuzztone. If it would be true for the Mk I, then somebody must have stolen it from this unit:
What do you mean AG?
Good catch AG
As I said:
I only believe what I see with my own eyes :wink:
I mean, that the picture shows the original innards of a MkI and that I cannot see a resistor in parallel to the poti there.
If you look at the near identical Maestro Fuzztone schematic (or guts) you will find this resistor. The MkI should be a clone of the fuzztone but wasn´t sold very often, maybe due to the patent of the Fuzztone.
IMHO for this reason the Fuzz Face circuit was used instead to avoid patent lawsuits. Nobody cared this time about silizium/germanium and whatever. The only important thing was that it should distort/produce a squarewave in any way.
The circuit was the "european/british answer" to the patent of the Fuzztone. A funny question is only, what came first: the TB Mk 1,5 or the Fuzz Face ?
vanessa
Post by vanessa »
That would require 10 transistors, I'm only counting 9 in this photo. There are no resistors on jacks or switches.
