Vector-based software templates (for stompboxes)
- Mr. G.
- my favorite amplifier: Undecided
- Completed builds: 3-loop + tuner out TB loop pedal
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Several LM386 based distortions - Location: Nova Scotia, Canada
- Has thanked: 1 time
- Been thanked: 9 times
I've noticed that several people on here use the vector graphics program Inkscape to do layouts and such with. So, why don't we start a collection of templates to use.
I've attached the template that I made for doing vero and perf layouts. It's missing several components, like trimmers, ICs with more than 8 pins, jacks, and such, but there should be enough there to get a good start. I keep the grid set to 2.54mm/.1" (not sure if that will translate in the file or not). Everything has/is on it's own layer to make it easier to work with.
Let me know if you have any problems with the file, or need any tips on how to work with the components.
Layout Template.svg.zip- Inkscape vero/perf template file.
- (24.61 KiB) Downloaded 1214 times
- lolbou
OK, that's a nice help when it comes to vero board...
Here's the file I have as to PCB tracing... Inspired (and even straightly copied from Francisco pena from http://www.tonepad.com... You can adjust the components sizes to your needs...
As for Mr G.'s file, the grid is 0.1" large, and when deplacing pads or so, the pointer is magnetized to the intersections of the grid...
I previously posted on the forum, so if it's one time too much, please take it away modman...
ps: both files can be mixed as they appear to use the same scales, so you can have a 2D rendition of your PCB on my file using the lovely components drawn by Mr. G.
"elle est pas belle la vie?"
PCBsvg.zip- PCB Layout for Inkscape
- (13.71 KiB) Downloaded 694 times
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- Mr. G.
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Thanks for the response lolbou! I saw the file you posted in another thread, and that's what inspired me to make this thread.
Inkscape is a great alternative to Adobe Illustrator and Corel Draw. I think it can be a touch glitchy when run on Windows, but as long as you save often, it shouldn't be a problem. I run it on Linux without any problems at all.
- lolbou
You're very welcome Mr G., and you're right about Inkscape being a nice (and free) alternative...
So am IMr. G. wrote:I run it on Linux without any problems at all.
- Completed builds: Tube reamer; Si Fuzz Face; Ge Fuzz Face; BSIAB II; SHO; Sparkleboost; Sparkledrive; Rat; Dist+; Echobase; ADA Flanger; Easyvibe; May Queen; Hot cake; Phase 90; Dr Boogie; Prof Tweed; Little Giant; Ruby; Modded Cry Baby wah; various power supplies
- Has thanked: 13 times
- Been thanked: 2 times
Cool, I've recently started using inkscape for my drill templates and artwork. I've been building up a component library and planned to upload to the inkscape site. I've attached what I've got so far below.
Rob.
Rob.
enclosures_and_components.zip- Enclosures and components in Inkscape format (zipped)
- (14.36 KiB) Downloaded 1232 times
- Mr. G.
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Good stuff! Thanks for the upload.
- quaternotetriplet
Anyone got 4knob drilling template like the hermida audio??
The component library I posted above has all you need to create your own. The beauty of something like inkscape is that you can quickly and easily make up accurate templates using a bunch of standard components.quaternotetriplet wrote:Anyone got 4knob drilling template like the hermida audio??
I've just spent today writing a python extension to generate dial markers to go around pot knobs.
Rob.
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
started looking at this tonight Rob and it's very coolralley wrote:The component library I posted above has all you need to create your own. The beauty of something like inkscape is that you can quickly and easily make up accurate templates using a bunch of standard components.quaternotetriplet wrote:Anyone got 4knob drilling template like the hermida audio??
Rob.
how exactly do you add components? (I want to add a small toggle switch in there and maybe a 3mm led too, just not sure of the process)
Hey, you stalking me or something?rocklander wrote: started looking at this tonight Rob and it's very cool![]()
Adding components is just a matter of drawing them manually and saving. I normally start with an existing component and modify it. I can add a 3mm LED with no problem. What do you want for the switch: a pretty external view or a template/outline sort of view? Also what config SPDT/DPDT etc.? If you can link to the sort of pic you want I'll add it to my library and re-upload.
Cheers, Rob.
- rocklander
- Contact:
dewd, I'm a stalker from way back
yeah, I'm thinking I want it for a drilling template, but also a 'fitting-in-the-box' kinda thing. so a centre point and hole size (for drilling) and a rear package square.. pins etc. aren't so important to me I guess, I was planning on using it more for box crammage and drilling.
the dpdt is prolly most common, although I use a 3pdt toggle for the black toast etc. (the mini toggle ones from futurlec), and of course others may like the spst one (like in the thor).. hell.. I dunno lol
- invalidcd
Here is a template i made for myself using parts of R.G.'s 1590BB layout and the Hammond CAD files. i hope this helps. Enjoy
XOX Electronix Enclosures & Drill Templates.svg.zip- (11.06 KiB) Downloaded 881 times
- Nikifena
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 69 times
- Been thanked: 65 times
- Contact:
Here are a couple of schematic symbols too : http://www.mbeckler.org/inkscape/circuit_symbols/
But for schematics and layouts, i recommand using a proper CAD tool (e.g. Eagle), it's much more efficient and eventually a bit easier. Inkscape remains great for all the rest : enclosure planning, drill templates, faceplates, knobs graduations, artwork ...
- Mr. G.
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Here's a PDF containing all of the tools that I use to make perfboard and veroboard layouts. The contents should be easily editable in any vector based program, such as Inkscape or Illustrator. The box to the right contains the components I normally use for board layouts and box layouts. The rest are just scaled down typical layouts with their corresponding drill template that I use. These are just what I try to use if my layout permits, so YMMV. The boxes are Hammond 1590a, 1590b, and 1590bb. To make a 1:1 drill template using them, just scale them up to the sizes shown by the dimensions.
I normally do all of my layouts in Eagle, and then I'll create a PDF and import it into Illustrator. From there, I'll recreate the layout in an easier to read "perf" or "vero" version. I also do this if I want to make fancy traces for PCB's as opposed to the straight lines and corner curves in Eagle.
Feel free to use the file anyway you like. Let me know if you have any trouble with the file, or if you find it useful.
Components2.pdf- vector layout creating tools
- (912.74 KiB) Downloaded 856 times
- Mr. G.
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Glad you like it! I can't contribute much as far as the circuits go, so I figured this was the next best thing that I could do.
If anybody has any suggestions for changes, I'm all ears.
- Mr. G.
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Thanks! I thought about putting it in that other thread, but it wasn't just for Inkscape. So, that's why I started the new thread. Thanks for merging them.
