Problems with PnP Blue toner tranfer
Posted: 13 Jan 2009, 19:53
by rutledj
I get good transfer to copper. Problem is that it is too good. A lot of my runs bleed together. Looking at the ckt on the PnP paper, it looks crisp and clear. Any suggestions how to get it crisp on the copper?
Thanks,
Rut
Re: Small problem with PnP Blue
Posted: 13 Jan 2009, 20:41
by sfx
It sounds like your iron is too hot and is melting the toner.
Posted: 13 Jan 2009, 21:04
by modman
For my first etching I had to wait some weeks while my batch of PNP was in the mail. By the time they arrived I found out that you could use
*inkjet paper in a laser printer
*more or less glossy magazine paper
*transparancy sheets
*ordinary paper:
viewtopic.php?f=22&t=492&p=5885
My batch of PNP is still untouched... never have any problems with smeared traces. Mostly use magazine paper without problems. An important advantage to everything but PNP is that you can use an exacto knife to punch whole in the transfer (where there's no toner) so the air can escape easily and you get optimum adherence to the copper board.
If your iron tends to stick to the transfer (happens sometimes with glossy paper) put a normal sheet of paper in between the iron and the transfer. This may also help when ironing on PNP, because it absorbs and diffuses the heat a bit.
Overheating is a real problem with PNP, you are not alone.
Good luck!
Moved to FAQs!
