lolbou
Posts: 2612 Joined: 18 Nov 2008, 21:38
Has thanked: 305 times
Been thanked: 220 times
Post
by lolbou » 26 Feb 2009, 19:01
Good!
I have the same pots in my Deluxe mistress... Do you know if they're still available?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
floris
Posts: 472 Joined: 14 Oct 2007, 12:05
Has thanked: 230 times
Been thanked: 72 times
Post
by floris » 26 Feb 2009, 23:08
Sorry, I have no idea where to find these pots.
lolbou
Post
by lolbou » 26 Feb 2009, 23:34
Well, these are CTS V450 ones (in my mistress)... There is a tiny logo on the upper side of the pot which i hadn't seen...
Thanks for replying..
DimebuGG
Posts: 218 Joined: 02 Sep 2008, 11:37
Has thanked: 8 times
Been thanked: 198 times
Post
by DimebuGG » 02 Mar 2009, 03:57
The other end of 1M resistor at IC2b(LM358) connected at the output(pin 7) also goes to pin 5?
floris
Post
by floris » 03 Mar 2009, 19:46
Yes, the opamp is used as schmitt-trigger.
Entrant_21
Posts: 104 Joined: 01 Apr 2008, 21:56
Been thanked: 3 times
Post
by Entrant_21 » 19 Apr 2009, 01:10
Does anybody know of a UK source for the CLM50? Or an easily adaptable alternative?
floris
Post
by floris » 19 Apr 2009, 09:51
You could also use a VTL5C2 vactrol ($4 or something) or make a LED/LDR combination yourself like this:
The homemade LED LDR was wrapped in shrinkwarp. First some small shrinkwrap (red, 3mm) for each component leg and then some larger shrinkwrap (black, 6mm) over both the LED and LDR. The small shrinkwrap isolates the individual component legs and lets the larger shrinkwrap close well down on the whole.
Rorer714
Posts: 91 Joined: 29 Sep 2008, 21:29
my favorite amplifier: Blues Junior
Completed builds: None yet. Some successful repairs though, which is a step in the right direction.
Been thanked: 4 times
Post
by Rorer714 » 21 Apr 2009, 21:05
Awesome! I really needed these shots! I broke a couple of wires off of the mic input when repairing a jack and couldn't remember where to put them back on. Thanks!
floris
Post
by floris » 22 Apr 2009, 09:07
Rorer714 wrote: I broke a couple of wires off of the mic input when repairing a jack and couldn't remember where to put them back on. Thanks!
To which "mic input" do you refer?
Rorer714
Post
by Rorer714 » 22 Apr 2009, 23:01
The large input on the side, isn't that for mics? I've never actually used that input but the pedal stopped working after the wires came off.
floris
Post
by floris » 25 Apr 2009, 09:02
Ah, the "lo-z out" output. A rather exotic output to have in a stompbox!
Rorer714
Post
by Rorer714 » 25 Apr 2009, 23:36
floris wrote: Ah, the "lo-z out" output. A rather exotic output to have in a stompbox!
Yeah that's it. It is rather strange that it should be on there.
Doesn't that make this box capable of being either a reamping device or a DI box?
Bernardduur
Posts: 1189 Joined: 24 Aug 2007, 07:36
Has thanked: 89 times
Been thanked: 645 times
Post
by Bernardduur » 26 Apr 2009, 10:52
Rorer714 wrote: floris wrote: Ah, the "lo-z out" output. A rather exotic output to have in a stompbox!
Yes; awesome......
didn't the MXR noise gate had the same feature?
I can't spot how this is connected here........
Posts: 4817 Joined: 19 Jun 2007, 16:57
Has thanked: 4287 times
Been thanked: 2008 times
Post
by modman » 02 May 2009, 09:07
sorry to go a bit off topic here:
what's the production date of these early DODs?
Maybe this is post 1975?
lolbou
Post
by lolbou » 02 May 2009, 11:48
there should be a date code below the pot which we can't see...
snafuX
Posts: 20 Joined: 18 Jan 2008, 19:15
Post
by snafuX » 13 Sep 2009, 19:11
yeah this works very good but is a little too slow in the reliese how can i make it more fast???
floris
Post
by floris » 13 Sep 2009, 22:23
Which optocoupler did you use?
The VTL5C1 (35ms), VTL5C3 (35ms) and VTL5C9 (50ms) have a much faster release that the VTL5C2 (500ms).
whosyourdaddy
Posts: 28 Joined: 12 Jul 2009, 12:15
Has thanked: 1 time
Been thanked: 7 times
Post
by whosyourdaddy » 30 Sep 2009, 23:06
Hello, does anyone have ready-for-print PCB for this pedal?
Posting it here would be much helpful.
tnx cheers
