DOD - 230 ( Noise Gate )
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
Scruffie wrote: 24 Feb 2022, 12:38 That's the envelope section, seems the audio is dealt with passively and the output is pin 2 of the 4066.
I know, I was looking at the schematic posted...
I think the pad marked OUT is actually the footswitch connection, other switch's pin should go to GND.
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
Here the schematic of the switching circuit with the 4066 IC in functional view.
Edit: The circuit diagram was incorrect and had to be corrected.
Manfred
Post by Manfred »
Unfortunately, I don't have the pot. Was thinking it might be 500k but not certain.
Thank you, your guess is right.
According to my calculations, the potentiometer must have a value of 500 Kiloohms for a threshold range from -70dBV to +10dbV.
Manfred
Post by Manfred »
Ready-to-print PDF-files:
DOD 230 PCB Component Side Top.pdf
(10.16 KiB) Downloaded 55 times
DOD 230 PCB Component Side Bottom.pdf
(1.79 KiB) Downloaded 55 times
MAXON D230 PCB Solderside.pdf
(6.02 KiB) Downloaded 51 times
Sprint-Layout 6.0-file:
DOD 230 Layout.zip
(16.14 KiB) Downloaded 52 times
Manfred
Post by Manfred »
I moved the 100k resistor from the bottom to the top, here the modified layout.
DOD 230 Layout Mod Component Side Top View.pdf
(10.7 KiB) Downloaded 47 times
DOD 230 Layout Mod Component Side Bottom View.pdf
(1.45 KiB) Downloaded 46 times
DOD 230 Layout Mod Solder Side.pdf
(6.1 KiB) Downloaded 46 times
Sprint-Layout 6.0 file:
DOD 230 Layout Mod.zip
(15.81 KiB) Downloaded 45 times
tarbush
Post by tarbush »
Fender3D wrote: 24 Feb 2022, 18:34
So, to make certain I understand, you are talking about the one that connects to pin 5 of the CD4066BCN? Thanks.
Fender3D
Post by Fender3D »
Yes, if you connect the pad connected to 4066's pin 5 to GND, via one (foot)switch, you will force the effect to be always on.
