That may be true (again, I'm not a pickup winding expert by any stretch), but in my experience the StingRay preamp doesn't react well to high anything, inductance and/or resistance... it wants both low inductance and low resistance... nature of the beast it seems.... my best guess is that they were designed to complement each other & specifically around each other... at least that would seem to make some logical sense... given what I've found... there may indeed be other ways to skin the cat... but for that classic "StingRay sound" that was all over rock radio in the late 70s & early 80s I haven't been able to make it come out of one with anything but having the pickup coils wired in parallel... giving a low inductance and low DC resistance.DavidRavenMoon wrote:Regarding these pickup models done in Spice, etc. They are close, but never really on the mark. Pickups are complex impedance devices. You can do high inductance and low resistance, and get a nice clear tone, or higher resistance and low inductance for a similar tone.
The modeling I've done recently with Bajaman's circuit just confirms & makes some sense out of my experience... not the other way around.
In the last decade I've had a couple of 'em brought to me that didn't sound "right"... none with original MM pickups... where they went and why is anyone's guess.
One with a pickup in it much like the one Jay is working with... a 4-wire copy that was wired in series... rewired it in parallel & that cured it.
Another where the owner thought it sounded "OK", but not all that deserving of the hype he'd read about (he'd bought it off eBay).. told him it didn't sound right to me so he told me to check it over... found a cheap knockoff 2-wire pickup that measured about 8.5K DC resistance... he stuck a Duncan replacement in it & was a happier man as he then "got it".
Then there was a 3rd one that was found (no lie) at a yard sale with no pickup in it, no strings on it, & no case (but otherwise in decent shape actually), purchased for the whopping sum of $20 & brought to me to see if it could be brought back to life (this one was just last summer)... owner opted to buy the EMG pickup (which I found had to be rewired for parallel), I replaced the battery connector & fixed a couple bad solder joints on the board... then after a few tweaks to the bridge height & intonation it was the 1980s all over again.
The only thing I really knew about the MM pickups until recently was that they were a dual coil wired in parallel & it's pretty common knowledge that parallel wired coils sound different than series... so I was just copying the MM format of making sure the coils were in parallel... not realizing until recently that the pickup wasn't the only trick up the SR's sleeve.
I didn't realize until I've had the chance to play with the circuit (again, thanks loads to Bajaman for that) how much the preamp's output is affected by it... or more correctly, ill-affected by a series configuration with it's higher resistance and inductance... all I knew was that it sounded like a SR when the pickup was wired in parallel... in series, not so much.
