Baja Music Man guitar and bass onboard preamps  [documentation]
oldschoolbassplayer
Post by oldschoolbassplayer »
Jarno wrote: 27 Sep 2021, 14:14 Start with the resistors, then capacitors, semiconductors (IC's, transistors) last.
But in general, lower/smaller components before bigger ones.
I almost want to build my own tube amp now! :D
I'm looking forward to this it should be fun.
oldschoolbassplayer
Jarno,
Did you know that solder has a shelf life? I have a 1-lb Kester .8mm (.031") 60/40 rosin core paper-weight manufactured Jul 07 17.
I guess I will not be buying any more 1-lb spools of solder, but before I go ahead and order less, I wondered if you had any solder thoughts or advice?
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 75 times
Post by Jarno »
Does it still work properly? If it does, don't worry about it.
As to my preference, I use Stannol solderwire, with lead, not sure if that's easy to get where you are. There are several variants I think I've used HS and HF, both have no-clean flux, and I do not clean my boards.
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
oldschoolbassplayer wrote: 28 Sep 2021, 22:57 Did you know that solder has a shelf life?
That's odd because I have a roll that I started sometime in the 80's and it hasn't gone off yet. :lol:
oldschoolbassplayer
I'm wondering how lead and tin go bad sitting is a closet? Probably the rosin core is what deteriorates but geez when I was a kid seems like a spool of solder lasted 10-years or you lost it...
What do you clean your boards with? Do you prep your boards in any particular way?
Are you an electronics guy that plays the bass or a bass player that knows electronics?
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
So many things! :D
Post by Jarno »
As mentioned in my post I do not clean, also no special preparation unless I etched boards myself, and they have been in a drawer for a while (very fine steel wool).
I myself am a mechanical engineer, with affiliation with electronics. The hobby has helped my career as well, I now lead a group of development engineers who do both mechanics and electronics (and software, really need to know more about that area) development.
Apart from that, a bassplayer, and I have built a rather big modular synth. :D
deltafred
Post by deltafred »
I've seen acid cored solder corrode over time but never rosin.
If needed (if they don't tin properly) I clean the solder pads with with a typist's eraser (a pencil shaped eraser where the "rubber" is loaded with fine sand). As we don't have typists anymore I guess that typist's erasures are no longer produced.
"Are you an electronics guy that plays the bass or a bass player that knows electronics?"
Good question, make your own mind up.
Back in the 60's I started messing with electronics when I was about 12 y.o. and started playing bass at 16. I worked in an electronics design lab in the early 70's then moved from design to commissioning and fault finding where I stayed until they moved the electronics design and production to another site. Software was in it's infancy and I retrained as a software engineer, finally ending up in software quality control where I was when I retired.
As far as bass playing goes I have been a weekend warrior since 1967 with occasional short breaks when life got in the way. I turned down a few opportunities to go pro because I had a family and a good career (with a pension at the end of it). I currently play in 3 bands and sub for a 4th.
oldschoolbassplayer
Thanks guys - its good to know I am not getting advice from a couple of "internet experts" :lol:
I am grateful for all your help.
oldschoolbassplayer
Any suggestions for a reasonably priced digital multi-meter that isn't junk?
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
So many things! :D
Post by Jarno »
Even the cheap ones are OK, still have one I bought from the dutch version of Home Depot a decade ago. Also have one from china which is OK (has capacitance and inductance measurements), I have a bench multimeter from Fluke which has seen better days (but it is more than 50 years old, and a dumpster find), and a analogue Hioki from the 80's which has no features, but always works (reading the dial is a bit of a puzzle).
flavio-san
Post by flavio-san »
Hi stompboxers, I've built the 2 band EQ preamp suggested by the great Bajaman (thank you Sir)
please find below my results
https://postimg.cc/ppqG3hq8
with pots:
https://postimg.cc/HrnZmYhN
FFT with EQ closed
https://postimg.cc/zHNKG7XB
FFT with Bass full open
https://postimg.cc/5QmvYz6m
FFT with bass and treble full open
https://postimg.cc/7brWzy5C
FFT with flat response (bass closed and treble somewhere near 3/4 open)
https://postimg.cc/dDRSmSC5
I will try this one on a P-J bass that I'm not using since the tone is not of my taste anymore (getting old maybe)
F
JudgeMingus
Completed builds: JH-1 renovation with mods for crisper tone
Tuner/Mute box with loop reverser (for Gilmour 'seagulls' wah effect)
Si Fuzz Face clone
Rat clone
Tonepad Rebote 2.5 echo
Phase 90 clone
MXR noise gate clone
Runoffgroove Professor Tweed
Distortion+ clone
OD250 clone
Fuzz Central Liquid Drive
MXR DynaComp clone
Orange Squeezer clone
Demeter Compulator clone
Skreddy Lunar Module clone
Dual-output buffers (derived from AMZ Super Buffer)
Several more under way!
Has thanked: 39 times
Been thanked: 8 times
Post by JudgeMingus »
To revive discussion of the 'typist' erasers mentioned above - they are still available:
I found some on http://www.erasersticks.com/block-erasers.html
and one at https://www.aroundtheoffice.com/Richard ... ER-4421-BN
I haven't tried the ones I linked, but I suspect any old fashioned ink eraser would be abrasive enough to polish off superficial oxidation from copper traces.
jeepe
Completed builds: I might be at level 2, so to speak..
not totally green, but that's all :)
my "level" is about building a big muff... medium complexity :)
I'll never build a DS-2, for example :)
even though I'm a layman to electronics
I'll never build anything without seeing the actual schematics too...
my all time favorite: Fuzz FAce
it is an always ongoing project..
I want to end up strumming some strings at the end of the day, whatever the sound
I'm so sad that this beautiful culture (and freedom movement) is totally ephemeral
Has thanked: 568 times
Been thanked: 21 times
Post by jeepe »
hi,
(sure, I'm aware that this thread is spanning over, from 2007 to this day, 15 years, but Coca Cola never excuses themselves for continuing, so why should we? :) )
So, I've just bumped into this 1K protection resistor soldered to the output jack, preventing sudden death of the IC when the signal input gets shorted...
http://www.musicmanbass.global/sr4-pups ... eb-part-1/
The IC chip can be damaged if the guitar lead becomes short-circuited (even momentarily). In 1982 the addition of an out-board 1K ohm protection resistor was recommended, and subsequently used, to protect the IC chip.
NOTE: The protection resistor is used in all new preamps, after its introduction, whether using either Tantalum or Electrolytic capacitors.
Do you guys usually add this resistor? I know, it is post '77, but this is just for safety, so why/not...?
pedal building, tracing and sharing is such a beautiful freedom movement... If only it could be viewed as a future heritage, but it really is ephemeral, as it seems
can't hurt to fit it
deltafred
Post by deltafred »
There was a problem with the very early preamps where the opamp was sometimes damaged when a guitar lead was plugged in. Adding the 1k resistor cured the problem.
Leave it out at your own risk.
jeepe
Post by jeepe »
thank you very much!
course I won't leave it out :) not because I'm cautious or anything, but I wouldn't be able to explain myself, should that accident happen, why I haven't applied it :)
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
So many things! :D
Post by Jarno »
As mentioned, can't hurt to fit it, but:
The datasheet for LM4250 explicitly mentions short circuit protection, so is this really needed?
Is this perhaps caused by the output cap?
jeepe
Post by jeepe »
hi, just one more bit of advice, I seek,
how about the 1.8nF capacitor?
what does it do, in the first lace? playing part in a filter? doing what exactly? (feels like I vaguely remember reading about this)
should we -- who still have a few lm4250-s -- use a ceramic cap, or chose a film cap, 1.5n or 2.2n?
(I have built it, using a ceramic cap, but I've broken my wrist and can't solder, nor can I play... for 4 weeks still)
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
So many things! :D
Post by Jarno »
I've used all sorts of caps, ceramic, film, styroflex, it's only rock and roll :D
Usually use 1n5, but recently I found 1n8, this influences the frequency where the tone controls work.
