Page 25 of 25
Re: Baja Music Man guitar and bass onboard preamps
Posted: 27 Sep 2021, 15:12
by oldschoolbassplayer
Jarno wrote: ↑27 Sep 2021, 14:14
Start with the resistors, then capacitors, semiconductors (IC's, transistors) last.
But in general, lower/smaller components before bigger ones.
I almost want to build my own tube amp now!
I'm looking forward to this it should be fun.
Posted: 28 Sep 2021, 22:57
Jarno,
Did you know that solder has a shelf life? I have a 1-lb Kester .8mm (.031") 60/40 rosin core paper-weight manufactured Jul 07 17.
I guess I will not be buying any more 1-lb spools of solder, but before I go ahead and order less, I wondered if you had any solder thoughts or advice?
Posted: 29 Sep 2021, 08:25
by Jarno
Does it still work properly? If it does, don't worry about it.
As to my preference, I use Stannol solderwire, with lead, not sure if that's easy to get where you are. There are several variants I think I've used HS and HF, both have no-clean flux, and I do not clean my boards.
Posted: 29 Sep 2021, 09:33
by deltafred
That's odd because I have a roll that I started sometime in the 80's and it hasn't gone off yet.
Posted: 29 Sep 2021, 09:39
I'm wondering how lead and tin go bad sitting is a closet? Probably the rosin core is what deteriorates but geez when I was a kid seems like a spool of solder lasted 10-years or you lost it...
What do you clean your boards with? Do you prep your boards in any particular way?
Are you an electronics guy that plays the bass or a bass player that knows electronics?
Posted: 29 Sep 2021, 09:54
by Jarno
As mentioned in my post I do not clean, also no special preparation unless I etched boards myself, and they have been in a drawer for a while (very fine steel wool).
I myself am a mechanical engineer, with affiliation with electronics. The hobby has helped my career as well, I now lead a group of development engineers who do both mechanics and electronics (and software, really need to know more about that area) development.
Apart from that, a bassplayer, and I have built a rather big modular synth.
Posted: 29 Sep 2021, 10:18
by deltafred
I've seen acid cored solder corrode over time but never rosin.
If needed (if they don't tin properly) I clean the solder pads with with a typist's eraser (a pencil shaped eraser where the "rubber" is loaded with fine sand). As we don't have typists anymore I guess that typist's erasures are no longer produced.
"Are you an electronics guy that plays the bass or a bass player that knows electronics?"
Good question, make your own mind up.
Back in the 60's I started messing with electronics when I was about 12 y.o. and started playing bass at 16. I worked in an electronics design lab in the early 70's then moved from design to commissioning and fault finding where I stayed until they moved the electronics design and production to another site. Software was in it's infancy and I retrained as a software engineer, finally ending up in software quality control where I was when I retired.
As far as bass playing goes I have been a weekend warrior since 1967 with occasional short breaks when life got in the way. I turned down a few opportunities to go pro because I had a family and a good career (with a pension at the end of it). I currently play in 3 bands and sub for a 4th.
Posted: 29 Sep 2021, 11:07
Thanks guys - its good to know I am not getting advice from a couple of "internet experts"
I am grateful for all your help.
Posted: 01 Oct 2021, 13:11
Any suggestions for a reasonably priced digital multi-meter that isn't junk?
Posted: 01 Oct 2021, 20:23
by Jarno
Even the cheap ones are OK, still have one I bought from the dutch version of Home Depot a decade ago. Also have one from china which is OK (has capacitance and inductance measurements), I have a bench multimeter from Fluke which has seen better days (but it is more than 50 years old, and a dumpster find), and a analogue Hioki from the 80's which has no features, but always works (reading the dial is a bit of a puzzle).
Posted: 11 Oct 2021, 13:28
by flavio-san
Hi stompboxers, I've built the 2 band EQ preamp suggested by the great Bajaman (thank you Sir)
please find below my results
https://postimg.cc/ppqG3hq8
with pots:
https://postimg.cc/HrnZmYhN
FFT with EQ closed
https://postimg.cc/zHNKG7XB
FFT with Bass full open
https://postimg.cc/5QmvYz6m
FFT with bass and treble full open
https://postimg.cc/7brWzy5C
FFT with flat response (bass closed and treble somewhere near 3/4 open)
https://postimg.cc/dDRSmSC5
I will try this one on a P-J bass that I'm not using since the tone is not of my taste anymore (getting old maybe)
F
Posted: 12 Oct 2021, 01:56
by JudgeMingus
To revive discussion of the 'typist' erasers mentioned above - they are still available:
I found some on
http://www.erasersticks.com/block-erasers.html
and one at
https://www.aroundtheoffice.com/Richard ... ER-4421-BN
I haven't tried the ones I linked, but I suspect any old fashioned ink eraser would be abrasive enough to polish off superficial oxidation from copper traces.
Posted: 07 Jul 2022, 11:50
by jeepe
hi,
(sure, I'm aware that this thread is spanning over, from 2007 to this day, 15 years, but Coca Cola never excuses themselves for continuing, so why should we?
So, I've just bumped into this 1K protection resistor soldered to the output jack, preventing sudden death of the IC when the signal input gets shorted...
http://www.musicmanbass.global/sr4-pups ... eb-part-1/
The IC chip can be damaged if the guitar lead becomes short-circuited (even momentarily). In 1982 the addition of an out-board 1K ohm protection resistor was recommended, and subsequently used, to protect the IC chip.
NOTE: The protection resistor is used in all new preamps, after its introduction, whether using either Tantalum or Electrolytic capacitors.
Do you guys usually add this resistor? I know, it is post '77, but this is just for safety, so why/not...?
Posted: 07 Jul 2022, 13:42
by bajaman
can't hurt to fit it
Posted: 08 Jul 2022, 09:54
by deltafred
There was a problem with the very early preamps where the opamp was sometimes damaged when a guitar lead was plugged in. Adding the 1k resistor cured the problem.
Leave it out at your own risk.
Posted: 09 Jul 2022, 10:27
by jeepe
thank you very much!
course I won't leave it out
not because I'm cautious or anything, but I wouldn't be able to explain myself, should that accident happen, why I haven't applied it
Posted: 11 Jul 2022, 09:15
by Jarno
As mentioned, can't hurt to fit it, but:
The datasheet for LM4250 explicitly mentions short circuit protection, so is this really needed?
Is this perhaps caused by the output cap?
Posted: 30 Jul 2022, 04:04
by jeepe
hi, just one more bit of advice, I seek,
how about the 1.8nF capacitor?
what does it do, in the first lace? playing part in a filter? doing what exactly? (feels like I vaguely remember reading about this)
should we -- who still have a few lm4250-s -- use a ceramic cap, or chose a film cap, 1.5n or 2.2n?
(I have built it, using a ceramic cap, but I've broken my wrist and can't solder, nor can I play... for 4 weeks still)
Posted: 16 Nov 2022, 08:47
by Jarno
I've used all sorts of caps, ceramic, film, styroflex, it's only rock and roll
Usually use 1n5, but recently I found 1n8, this influences the frequency where the tone controls work.
