Will a JFET work as a clipper?
TubeDude22
Has thanked: 16 times
Been thanked: 19 times
Post by TubeDude22 »
Title says it all. Can a JFET clip like a MOSFET if the gate and drain are tied together?
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
By shorting drain and source, using that as one end and the gate as the other end, you can make a low-leakage diode. Other than that, no.
