i'd like to show you the amp i'm working on the last few months.
The aim was to build an amp using the least parts count possible, but including some unusual details making it some kind of "special" among others.
It's not as "simple" as a Champ and i had to compromise with the powersupply and the output-transformer aswell as with the chassis as i took them from an old DIY-amp bought on evilbay for about 100€.
Here's the schematic
The first tube-stage is taken from the "bassomat" from kpt.Maritim (very nice guy i owe him a lot) from the tube-town-forum, i'm still testing different anode- and cathode-resistors there but i cant decide what sounds best, same with the cathode-capacitors. Frankly said i prefer the sound without any cathode-capacitors in the first two stages.
Still enough gain for my Sandberg bass.
The phase-inverter stage is inspired by the Ampeg Portaflex amps, a floating paraphase. I included a switchable "symmetry-control" allowing asymmetry up to some kind of "pseudo-single-end", giving a lot of warmth and a slight distortion.
The output-stage is nearly 1:1 the one of a Dynacord Bass King, nothing special in there. There i had to compromise with the power-transformer as it gives me about 500VDC, i'd like more to have a cathode-biased class-A/B power amp.
Screen voltage on the EL34 is 495VDC, pretty high. The Valvos don't care, nothing glows except of the heaters, but i won't rely on that.
Next thing would be therefore a choke-input-power-supply lowering the HT to approx. 320VDC.
That's all so far, further changes will be mentioned here aswell as in german at the tube-town-forum.
Ideas, warnings, tips are welcome as i have all my knowledge on tube-amps from reading in books or the internet, but they don't tell you if you misunderstood something.
regards
Mathias
