Voltage for Aluminum Electronlic Resistors
Dallas
Post by Dallas »
The FAQ section has listed 50v electrolic resistors. Noticed at Mouser that the 50v are about $.21 and the 25v are about $.06 each. Do I need more than a 25v rating for a 9v stompbox?
Is there some other advantage to more volts? They are a little bigger it looks like.
Kind of clueless...
Dallas
Post by Dallas »
SORRY - the title of this thread was completely butchered.
Should read Elecrolytic Capacitors.
What an idiot. :shock:
Well, it can only go uphill from here --- :horsey:
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
The voltage rating should be at least equal to the maximum voltage the cap will have on it. Adding 50% is a good idea for reliability. 50V will still work fine, but like you said they're larger/more expensive. You would be fine with all 16V caps.
Ronsonic
Post by Ronsonic »
There's no advantage in the 50V rated cap, unless you just like bigger. Stick with 25V if you ever anticipate running at 18V, or 16V caps if you'll keep it to 9 - 12V.
My Pedals, Products, Services and DIY Blog: http://ronbalesfx.blogspot.com/
