Fairfield Circuitry - The Barbershop (gut)  [traced]
MicMicMan
Has thanked: 15 times
Been thanked: 9 times
Post by MicMicMan »
you are speaking about replacing those decoupling caps from 10uF to 4.7uF right ? then they'll let a bit less bass through
fairfield
Been thanked: 25 times
Post by fairfield »
Yea, less bass with 4.7uF at source.
The zener is there to protect the mosfet. Max Vgs is 20V, in the rare case that this would happen, the zener would limit this to whatever value you got. I'm not sure about this but I think you could still use 18V with a 12V zener. As the zener conducts, the voltage drop on the 2M resistor goes up...
In any case, using The Barbershop with a supply higher than 9V is kinda lame. It becomes too clean, and the Sag knob doesn't have the same effect. I don't even think the circuit would clip at any setting if you used an 18V supply.
You could lower the resistor between the two gain stages, right before the drive pot, sending the 2nd stage into saturation much quicker... it becomes a different pedal.
Have fun with your build.
Guillaume Fairfield
Fairfield Circuitry
MicMicMan
Post by MicMicMan »
fairfield wrote:The zener is there to protect the mosfet. Max Vgs is 20V, in the rare case that this would happen, the zener would limit this to whatever value you got. I'm not sure about this but I think you could still use 18V with a 12V zener. As the zener conducts, the voltage drop on the 2M resistor goes up...
I think the tension limit accepted would be 12V (zener value) + the Vgd threshold of the mosfet (given it's a p channel), right ?
jwpartain1
Has thanked: 51 times
Been thanked: 60 times
Post by jwpartain1 »
Hey, just got this pedal together, I think I'm having trouble with the 3DPT. Bypass signal gets through, but when I engage the effect, it's like I'm still in bypass. Can somebody check this for me? :)
On the 3DPT:
Top left lug: I've got Input from board and a jump to bottom-middle lug
Top-mid: LED ground
Top- right : board output
Mid-left: IN jack
Mid-mid: grounds
Mid-right: OUT jack
Bottom left: jump to bottom-right lug
Thanks you guys.
jwpartain1
Or I might be getting thourhg the bypass in the right way.. My drive knob makes the signal bassier with the SAG all the way back, but other than that no big changes other than minor volume changes when I mess with knobs. Any ideas from y'all who have the circuit down?
jwpartain1
OK, so I've got signal, I had a problem with the way the SAG control was wired. Now, I'm getting signal through, but unity gain is max on the volume pot.. The signal I'm getting through is something like a light ring-mod, sorta distorted. I thought voltages might be the problem, so I checked the voltages at several points til I came up to lug 1 of the SAG pot (lefts the voltage out to the 2 JFETS and 2n2222) and measured 3.8V (9 V battery was approx 7.5V) when all the way open and 3.6 V when closed. I've checked the signal path and everything is kosher, so any ideas why I'm getting such a huge V drop across the sag pot?
jwpartain1
Should the SAG pot really be wired as shown in WhiteKeyhole's schem? With 2 & 3 wired together?
fairfield
Post by fairfield »
Sounds like the sag is wired as a fixed 10k resistor. Make sure you're using the 2nd schematic on page 3. And yes, lug 2 and 3 are wired together.
Guillaume Fairfield
Fairfield Circuitry
jwpartain1
Thanks Mr. Fairfield, I had several problems with my build that are now fixed, I mistook GATE for SOURCE on the J201's... :slap: This pedal is awesome, and a super design.
..now I'm just GAS-ing for your Randy's Revenge! Have a good one y'all.
jwpartain1
Hey, just wanted to share my build, first build actually. My wife painted it for me using acrylic paint (brushed) and we sprayed a lacquer on top. The switch on the side puts a 15k resistor in parallel with R6, dropping R6 to something like 10K if I'm correct. Mr. Fairfield had suggested subbing in a smaller value for R6, so I tried it out, sounds dirty :) Anyways, thanks to Mr. Fairfield and everyone else here.
And about the guy, we couldn't tell if "Barbershop OD" was referring to a barbershop quartet or.. an actual barber-shop, so we combined the two! The candy-cane was supposed to be a reference to a barber's pole.
asimplesample
Post by asimplesample »
Hey, y'all...my contribution to the thread. Not built, but I think it's okay.
astatine
Post by astatine »
I built this one, but having a bit of trouble with the sag control - the pedal only passes sound from 0 - 5. It sounds amazing when full on, so I really want to get this sorted!
My voltages are
q1 - D 5.78 S 0.73 G 0
q2 - D 6.37 S 0.51 G 0
q3 - C 9.3 B6.37 E 5.81
Any ideas? Do those bias voltages look okay?
cortezthekiller
my favorite amplifier: A large highway overpass
Has thanked: 20 times
Been thanked: 52 times
Post by cortezthekiller »
Hey,
I posted the layout for the Barbershop on page 2 which I drew on paper traced from an actual unit. It shows that the last stage transistor (2N2222) is actually oriented upside-down compared to the "verified" schematic. I've built a few units with the 2N2222 upside down as shown in the drawing and it works quite well. Is there anyone who can verify if that is the actual orientation in the barbershop or if I somehow drew it backwards, built it backwards, and had it work?
cdeschenes
Has thanked: 34 times
Been thanked: 19 times
Post by cdeschenes »
asimplesample wrote:Image
Verified this layout and it works flawless. Instead of a sag pot I used a dpdt switch with 2 resistors to get 9v, 7v and 5v since they seem the be the setting I used the most.
pietro_moog
Been thanked: 48 times
Post by pietro_moog »
astatine wrote:I built this one, but having a bit of trouble with the sag control - the pedal only passes sound from 0 - 5. It sounds amazing when full on, so I really want to get this sorted!
My voltages are
i have the same problem here
1bottom
Post by 1bottom »
Hi everyone.
Im trying to build this pedal, but I've found about 5 different layouts and there are some differences in parts.
They all agree on Q1 & 2 being J201's, and the Q3 being a 2N2222.
IS the ATP2222A a good replacement for the 2N2222?
And in some schematics, they have a Q4 VP3203 > others omit this. Is this part necessary or not?
:scratch:
Lastly, does the wattage rating of the 15v Zener Diode make much of a difference?
Thanks guys.
knutolai
Post by knutolai »
Read the thread. You can use a series diode instead of Q4, D1, R10, R11.
BuzzKing
Post by BuzzKing »
Anyone have any info about the new Millennium Edition Barbershop? I was gonna build a second Barbershop for my small pedalboard. Haven't found a schematic or vero layout. Would love to build the new edition,
Rick
jighead81
Has thanked: 31 times
Post by jighead81 »
Looks like there's a tone switch on it now?
FremenWarrior
Post by FremenWarrior »
The tone switch could change between different capacitors to cut the highs (ex: none-100pF-500pF).
Whats the purpose of the 47 ohms resistor (R10)? is part of the protection circuit?
