IC functioning
cacophony
Post by cacophony »
How will you know if an IC is functioning or not using a DMM? Are there any ways on how to check it?
not easy to do, but if the IC op amp is in the circuit and you have the 9 volt power supply connected and turned on, measure the voltage at the output terminal of the op amp ( 2 terminals if dual op amp etc.) - it should read very close to 4.5v dc if the op amp is functioning correctly (assuming you have the correct passive components in place - if it reads 9v dc then you have a problem. :wink:
cpm
Been thanked: 50 times
Post by cpm »
and then again....
how do you measure voltage without a DMM? :lol:
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
Using the tools you were given by nature: tongue, wet fingers, ...
You will get better with more experience.
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
If it should read 4.5V, use a LED and resistor...
ex: a 2.2V:20mA LED with a 4.5V voltage supply should have a (4.5-2.2)/0.020 = 115 ohm resistor in series not to burn.
If the LED lights correctly, then you're close to 4.5V...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
