Midi switching??
- lolbou
I do not know enough about relay switching... The only stuff I really understand is there (french, sorry) http://www.sonelec-musique.com/electron ... s_001.html
And i'm definitely not familiar with MIDI...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- marshmellow
teddybear wrote:which one should i choose Micro-controller (midi) or relay?
You have to ask the question differently. Because the µC (being it as a MIDI controller or not) is only there to control the relays or switches that are to be used. But it never gets in touch with any audio signal. So instead of the controller you could build up some logic using some good old flip flops or latches.
For the actual audio switches: instead of the relays you might use FETs or opto couplers.
Hope that answers your question. If you would be more specific about what you want and how you want to do it I could say more.
