Catalinbread - Dirty Little Secret [traced]
- pietro_moog
so we don't have a vero layout for now?
- Nicht Bernd
Looks like it's for either version 1 or 2 and not the MKIII. Don't think it's that hard to change it to match the schematic of the DLS MKIII though.
- Nicht Bernd
[/quote]
Looks like it's for either version 1 or 2 and not the MKIII. Don't think it's that hard to change it to match the schematic of the DLS MKIII though.[/quote]
You just have to ask him to do MKIII...
- Ice-9
connect lug 1 and 2 of the trimmer together.mganzer wrote:I remake the schematic in eagle. i dont know how is the conection of trimmer...anyone help?
Double check on components name and values already made...
- mganzer
Thank you loylo and Ice9
Guys, this is my very very first layout. Is only lead mode and sorry for the 4 jumpers...
Any constructive critcizmm is welcome. If everything is ok feel free to test. I'm out of fets to do by myself.
dlsmk3leadv1.pdf- (1.26 MiB) Downloaded 376 times
- mmolteratx
- Degoop Doctor
Couple of things I see immediately. Your high-z input trace is really long. That's really bad practice, as it's very susceptible to noise. It's basically an antenna and the shorter you can make it, the better. Second, your jumper pads are far too small.
- roseblood11
People, make layouts that include a voltage doubler!!! (See ICL7660S datasheet for schematic)
This kind of pedals really profits from 18V.
I'll do a vero based on my layout for the Galileo, but my day job eats my life at the moment...
- mganzer
Mmolteratx i dont understand what you mean by high z input. The big traces are (q2-c6-r4-c7) (q1-r2-c2) (bass1-2 to mid 1) (q1-q3-c6) (c13-q3-r12-r15).
Already change the jumper pads from auto to 0.056.
- jymaze
Well, before this 1 inch of trace on the PCB there will be 10 feet of cable and a pickup in front of the High Z input so I am not sure this 1 inch will change anything in term of the whole input chain being an antenna.
- azrael
Been a while since I did a single sided layout, but I figured I'd take some time and knock it out.
Put an LT1054 charge pump.
I like putting the DC jack on top, so I leave a cutout on the top. I left ground pads next to the I/O for shielded wire, and kept them pretty short. Used a 125B, didn't seem feasible single sided in a 1590B.
I'm not rather happy with the routing on top, but TMB wiring is always a pain in the if you want to keep them in that order...Kept some ground plane in between the long traces, so that'll help.
If people are interested, I'll post a PDF and whatnot.
schematic
https://i131.photobucket.com/albums/p31 ... atic-8.png
if anyone wants to check for errors, that'd be great.
schematic
- Ice-9
Thanks for the layoutazrael wrote:Been a while since I did a single sided layout, but I figured I'd take some time and knock it out.
[ Image ]
schematic
