Make a LOG pot out of a LIN pot?
kierc
my favorite amplifier: Vox Cambridge 30 R Twin
Completed builds: Clyde McCoy Wah with Whipple+Red Fasel inductor switch, Fuzz Face with own layout
Post by kierc »
Is it possible to say get a 100k Lin pot, do some electric voodoo, and end up with a 100k Log pot??
I did a googley search but most stuff is amp related, but I found something that said a resistor of about 20% value of the pot across lugs 1 and the wiper would create a Log pot... would this work for pedals? :scratch:
Kier.
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
By adding a 10k resistor between pin one and wiper. (see image)
edit: if you have a 4k7 lin pot, then add a 470 ohms resistor, and so on...
Try this http://www.sonelec-musique.com/logiciel ... curve.html, still from http://www.sonelec-musique.com which a french site I simply adore...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
kierc
Post by kierc »
Cheers for that :thumbsup
So it's 10% of the value?
Also, that's looking at the back of the pot right?
Am I right in thinking (from that French site) that if the resistor is placed on the other side it will create a reverse-log pot?
Cheers for the speedy helpful reply 8)
lolbou
Post by lolbou »
kierc wrote:So it's 10% of the value?
yes. when you lower the resistance value (starting from the pot value), then you lean towards a log curve. This very log curve is almost reached for 10% of the value.
kierc wrote:Also, that's looking at the back of the pot right?
yes again. the resistor goes between the "zero lug" and the center lug.
kierc wrote:Am I right in thinking (from that French site) that if the resistor is placed on the other side it will create a reverse-log pot?
that's it. french ain't that difficult, uh? :wink:
Here's the english by famous R.G. Keen... http://www.geofex.com/article_folders/p ... tscret.htm
kierc wrote:Cheers for the speedy helpful reply
My pleasure! :D
