drilling steel cases?
Frequently asked questions about tools and instruments used in stompbox development.
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
Definately doable, better with HSS bits than unibit. And maybe some lubricant/coolant.
Just be patient.
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Aluminium is fairly "soft" as compared to steel...
Use bits progressively (getting bigger of course, every mm or two), and a fast drilling machine (high speed only, or you'll make a triangle hole).
A "drill stand/holder" would be safe for your fingers...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
Reginald
Post by Reginald »
Drilling steel isn't too difficult if you have sharp bits. If I were you I'd buy a good 1/8" bit for drilling pilot holes, and some bits in whatever size you need. You can always sharpen them again.
I've drilled those exact cases with a Unibit without too much trouble. You might need a higher-powered drill depending on how much torque your cordless can deliver... I've seen some cordless ones that are pretty juicy so maybe you'll be fine.
willc1968
my favorite amplifier: Kustom K 200 A-4 in red
Completed builds: kay fuzz, clark fuzz, ea tremelo, green ringer, tremelus lune, a few big muffs, fuzz face and factory, sft, woolly mamoth, a bunch of tonebenders and many more that need to be boxed
Has thanked: 20 times
Post by willc1968 »
definitely try to start out with a pilot hole and keep the bits well lubed. i will have a cap off a quart container of oil half filled and dip the bit in there prior to drilling the hole. when using the larger bits i will do a few drops of 3 in1 oil while drilling. also if you dont have one a drill press is the way to go. i got my little delta brand new for under $80 about 15 years ago. i am sure one can be had in the used market for a reasonable price. also new or well sharpened high speed steel bit are best for metal cases but i have had good luck with the cheap reconditioned carbide bits for drilling my pcbs.
Scruffie
Has thanked: 28 times
Been thanked: 169 times
Post by Scruffie »
I had a steel scratch plate drilled out for my guitar, I just took it to a local hardware type shop and they drilled out 3 holes for about £2 so that could be a possibility if your near anywhere that might have a decent drill, just an idea.
