Toner transfer as pseudo screen print?
Frequent question about boxes and accessories: painting, etching, clearcoating, lettering, glueing, and so on.
Mr. G.
my favorite amplifier: Undecided
Completed builds: 3-loop + tuner out TB loop pedal
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Several LM386 based distortions
Been thanked: 9 times
Post by Mr. G. »
Would there be any problems with using the toner transfer method on a painted enclosure as sort of a pseudo screen print job? Would you need to use a high-temperature type of paint? Would the toner even stick to the paint? Would the clear coat stick to the toner?
I'm sure it would just be easier to get some clear decal type of label, but it's something that popped in my head. So, I thought I'd ask if it can be done. Anybody ever try it?
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
I've seen that toner transfer is sometimes used as a "silkscreen" on component side of PCB. It's just black instead of white.
I can't see a reason for it not to work on enclosures also ... like these etched ones: https://www.freestompboxes.org/viewtopic ... 442#p39442
Mr. G.
YATS (many)
BOR
DLS
COT (Briggs mods)
Crunchbox
SHO (several)
Fuzz Factory
Post by Mr. G. »
I'll probably give it a try on one of my "temporary/test" enclosures first. I was mainly just worried about messing up the paint from the heat of the iron.
HydrozeenElectronics
my favorite amplifier: Marshall JCM 800 4210
Post by HydrozeenElectronics »
That's a good idea, I hope some one tries it and lets us know.
JudgeMingus
Completed builds: JH-1 renovation with mods for crisper tone
Tuner/Mute box with loop reverser (for Gilmour 'seagulls' wah effect)
Si Fuzz Face clone
Rat clone
Tonepad Rebote 2.5 echo
Phase 90 clone
MXR noise gate clone
Runoffgroove Professor Tweed
Distortion+ clone
OD250 clone
Fuzz Central Liquid Drive
MXR DynaComp clone
Orange Squeezer clone
Demeter Compulator clone
Skreddy Lunar Module clone
Dual-output buffers (derived from AMZ Super Buffer)
Several more under way!
Has thanked: 39 times
Been thanked: 8 times
Post by JudgeMingus »
I have done this once on a PedalPartsPlus prepainted enclosure.
The surface of the enclosure needs to be very flat to iron onto well.
Also - the press+peel blue layer came off on the enclosure too!
It did clean off with methylated spirits (toner was fine), leaving the finish dulled where it had adhered.
The clear coat hid the dullness perfectly, though. It also crazed, but I think it was a poor choice of clear coat.
arcaarca
Has thanked: 28 times
Post by arcaarca »
I've made tone transfer using a gloss sheet of paper from a magazine. I use it like press'n'peel paper and I iron it on my enclosure for 4-5 minutes.
Here's the results:
https://img194.imageshack.us/f/zcout2.jpg/
http://www.fennecelectronics.it/smf/ind ... 7783;image
I protect the transfer with a transparent adhesive.
monkeyxx
Has thanked: 52 times
Been thanked: 49 times
Post by monkeyxx »
I have tried this a couple times on PAINTED enclosures with bad results. the hot iron screws up spray paint or powdercoat very quickly. I would recommend keeping this method to bare metal enclosures, like the one pictured above, or a really distressed paint job that's already screwed up looking anyway. This has been my experience, anyway.
I also have a hard time getting the glossy clear layer of photo paper to come off of the surface...I will have to try the methylated spirits trick next time to see if that helps, thanks for the tip
SpeckStudio
Post by SpeckStudio »
I'm actually about to try this tonight. I'll let you know how it goes... Or fails, haha.
SpeckStudio
Yeah. Total fail, no go on a painted box. The paint preferred to adhere to the paper before the toner transferred.
JudgeMingus
Si Fuzz Face clone
Rat clone
Phase 90 clone
Distortion+ clone
OD250 clone
MXR DynaComp clone
I have had a few more tries with this on powdercoated Pedal Parts Plus boxes.
The results have been mixed - it always leaves the paint matt in places, but some finishes come up pretty well if a clear coat is added over the top.
The worst problem is using press+peel blue leaves blue traces in the finish which cannot be hidden.
I am going to try removing the excess blue with methylated spirits before ironing next time...
