Tone Generation for debug/building
Frequently asked questions about tools and instruments used in stompbox development.
Grathan
Post by Grathan »
Looking for some ideas since strumming a guitar while testing can be such a hassle.
hooking up an ipod that loops a recorded guitar signal?
This seems like it might work, but is the signal even ac? Is there a way to make this work so that the output of the effect being tested gives similar results like a true guitar signal?
what other methods can be used?
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Frequency generator? Some can be easy to do, but do not really sound like guitar strumming...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
Fuzzer
Been thanked: 21 times
Post by Fuzzer »
Courtesy of RG Keen;
http://www.geofex.com/FX_images/q+dosc.gif
Other thing you can do is, if you have a delay capable of repeating a loop (DD-3 (hold), for example), that's your guitar signal generator.
lolbou
Post by lolbou »
That's one I thought of fuzzer... I like this one too: http://www.nuxie1.com/guides/function-generator.html
Grathan
Post by Grathan »
looks neat, of course I messed it up... :roll:
On the RG keen Twin Tee iscillator
1.) does this require 2 seperate 9v sources or can I just jumper the 9v+ hookups together?
2.) Is that a connection where the lines cross under the 4.7k?
3.) how do you hook this up?
Let's say I have an input and output wire from an effect I would like to run this signal through. Do I just take the 100mv lead and attach it to the input wire for the effect I wanna test out?
Fuzzer
Post by Fuzzer »
1) No, that's the same voltage node, you only need one battery.
2)Yes, it is a connection.
3) Yes, that's it, the output goes to the amp; or you start testing with the audio probe connected to the amp if that's the case.
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
If you have a scope, a couple things might prove useful:
A triangle wave will more clearly show distortion/asymmetry rather than a sine (which is already rounded at the top).
The option for symmetric/asymmetric waveform can prove useful when sorting out phase inversion.
HydrozeenElectronics
my favorite amplifier: Marshall JCM 800 4210
Post by HydrozeenElectronics »
If you wanted to change the frequency of the RG Keen signal generator what parts would you change? like say if I wanted to had a couple switches so I could choose between three different tones.
thanks
