DIY Mic Preamp (how about some distortion on the vocals)
nihoneiga
my favorite amplifier: 63' Fender Bandmaster
Completed builds: Maestro MFZ-1 (my favorite), 1977 Big Muff, Fuzz Factory, EA Tremolo, Super Hard-on, ROG Tubescreamer
Post by nihoneiga »
Hi there, lately I've gotten back into recording, or at least am thinking about it for the first time in a while and pulled out my Shure SM57 mic but was wondering how I could get more out it. A friend suggested a mic preamp but I'm not really committed to shelling out $$$ for a tube preamp etc so I was wondering if anyone had a design for a DIY mic preamp?
If it had any features beyond gain that could be cool. Basically, I'd like it to sound kind of broken up or otherwise kind of fuzzy. How is this effect usually achieved?
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
This topic definitely doesn't go in this forum. But I'll be damned if I can figure out where I should move it. Any suggestions?
SpencerPedals
Post by SpencerPedals »
I know you said you want to use your SM-57 and possibly build a preamp, which I do not know how to do, but one cheap alternative if you're looking for fuzzy vocals can be found here:
http://harmonica.typepad.com/i-mic/myimic_sd.swf
Singing through a bullet mic breaks up vocals in a very natural, unprocessed way. I built one before I ever got into this crazy pedal building stuff and it was super easy then, so you shouldn't have a problem with it at all. You can find crystal/ceramic mic cartridges on ebay or from old CB microphones. I made one with a new style CB mic cartridge and it sounded too clear (not the old style cartridge), so just make sure it's old if you do that.
puppiesonacid
Been thanked: 12 times
Post by puppiesonacid »
how about the diy FAQ section? although it may not be a FAQ is is a diy question nonetheless..
John3
my favorite amplifier: Musicman 210-65
Completed builds: BYOC 250+
1-Knob Fuzz
Orange Sunshine
Fuzzy Elephant
Master Volume SHO
Post by John3 »
There are a couple of sites online that sell kits:
http://www.fivefishstudios.com/
http://www.seventhcircleaudio.com/products.htm
http://www.paia.com/index.asp
I started building kits and now am working on veroboard in hopes of graduating on to some of the Neve clones. Also check out
http://www.jensen-transformers.com/apps_sc.html#mic
if you want to do it all yourself. Jensen is the name in pro-audio transformers and they are the "J" in Whirlwind and Radial's DI boxes.
John
.Mike
Been thanked: 31 times
Post by .Mike »
No distortion and only gain, but the price is right... heh.
http://www.audiomasterclass.com/arc.cfm ... with-audio
My website: America's Debate | My effects site: Just one more build...
John3
1-Knob Fuzz
Orange Sunshine
Fuzzy Elephant
Master Volume SHO
Post by John3 »
Alright, maybe I missed part of the question. Most engineers would use a preamp in conjunction with an insert jack(s) on a channel strip of the console or use an effects send and return it to another channel. If you built a preamp you could wire in a place to insert a dirt box of your choice. You have one or two don't you? Up next for me is an OCD clone so I can try it as in insert on a channel for an experiment. So anyone know where I can find a TL082 or what's a good sub?
John
My cheap-o PreSonus BlueTube gets a good musical distortion when maxed out.
With that in mind... perhaps the PAiA mic preamp with the tube in it might be a good choice.
When I use a mic preamp for distortion, I put a compressor after it to act as a limiter to bring the level down to something manageable for recording... since cranking the pre all the way to distortion usually makes a signal that's way too much.
