Boot-Leg Effectors - Jazz Fuzz JZF-1.0 [traced]
- rhandy gaye
hi,
thers'e a mistake on the pcb.
the ground out pad that runs under r7 and d1 continues to connect to the entire ground plain line.
if you wire the switching differently to the way boot-leg do stuff it may not work, as the ground plaine is broken.
cheers.
cheers.
- kaycee
My build of this one:
Built on vero from the schemo and PCB layout in this thread, if anyone is interested I'll draw it up neat and post it here. Used a 741 for the op-amp, didn't even try anything else - 4001's for the diodes in sym and asym on the toggle switch, I'd probably use a rotary and throw in a few more combo's if I built it again.
Thanks to the folks who contributed the info on this
- picassochild
Hey kaycee, how you like Jazz Fuzz?
- kaycee
picassochild wrote:Hey kaycee, how you like Jazz Fuzz?
I think that its very nice actually
No clips at the moment, most of my gear is going into storage as I'm in the process of moving.
- mirosol
I know it is 2,5 years since the question, but i drew one up.... Currently unverified...gurishka wrote:Hey, anyone got a perfboard layout or vero layout of this?
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
- mirosol
Not anymore. One of our blog readers just built it...mirosol wrote:Currently unverified...
+m
- LaceSensor
Surely you are missing a trace cut under that horizontal 100k Resistor on the bottom row...
