Little VOODOO VIBE project by Kaputepalla  [documentation]
Kaputepalla's Little Voodoo Vibe project files (ZIPPED PDFs)
  • This ZIP file contains the following:
    Corrected audio schematic
    Corrected oscillator schematic
    PCB transfer file
    Parts layout file
    Component values
I will draw up a BOM for this if this arouses interest, but please Alessandro, chime in and tell us about it. Any comments are very welcome...
Big thanks!
PDF converted: viewtopic.php?f=13&p=31158#p31158
littlevoodoovibe.zip
(146.27 KiB) Downloaded 150 times
alessandro
Been thanked: 13 times
Post by alessandro »
Hi there! This project is called little because of its PCB dimensions! I have made one of this and it's mounted on my pedalboard and always light on! Never heard a mutiple sound machine like this before! LED are yellow type clear bodied 5mm and LDR are miniature type! I separated audio path from the led driver to prevent click! Rotary switch are off board! If you have some question I'm very happy to help this wonderfull forum and all you my friend! Bye
hi allesandro,
Just to make sure, what are the pcb dimensions for the transfer?
mm
alessandro
The measures are 125mmx103mm(little board frame included)!I'll tell you some tricks when you'll end the pcb and send to you the photos!Do you want to see the true double faced layout?
CIAO!!!
alnico
Been thanked: 5 times
Post by alnico »
I can't download the files from that site. What are the corrections?
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
Hey man!
Thanks! I needed this for so long...... will build it quite soon!
Alessandro sent the files to me. Above 4 zipped pdfs:
VOODOOVIBE DELUXE LAYOUT.pdf 48K
VOODOOVIBE PCB LATO A.pdf 31K
VOODOOVIBE PCB LATO B.pdf 29K
VODOOVIBE LAYOUT CONNECTIONS.pdf 49K
Note that the little Voodoo Vibe is exactly the same circuit, on smaller pcbs. The original unit uses a double-sided pcb.
Alessandro in private mail to me wrote:This is by now a gift for you experienced dyer! I did't build this original version because i never make a double faces pcb! This costed me months of hard work but i think it's the king of cloned pedals! The components and the schematic are the same of the little voodoovibe (and now you'll know because mine is called 'little')
don't thank the messenger!
Noboby dare build this one without leaving us with a build report ! :D
Has thanked: 218 times
Been thanked: 857 times
Allessandro,
Get out the WD40! It seems your caps lock button is stuck.
Shit - I,ve been waiting for this one - I've just etched the board and drilled the holes - crosseyed now :lol:
Should fit nicely in a 1790 NSC box - done the graphic front panel label - Rotary Effect will have to wait until this one is built - I will take some build photos too - many thanks my Italian friend :wink:
alessandro
Enjoy!The voodoovibe and the memory man complete projects are my gifts to this forum!Don't be bad guys i've somenthing else to give!Ciao!
freedreamer
Post by freedreamer »
another italian member alessandro ? :)
me too :)
Bernardduur
Awesome
On the to-do list!
alessandro
Nice to meet you freedreamer try the project i've done!I'm italian and it seems that you too!?Ciao da Alessandro Kaputepalla!
freedreamer
yes i'm italian too :) i'll try your project .. thanks!
gnognofasciani
Been thanked: 11 times
Post by gnognofasciani »
Ce ne sono un bel po' di Italiani :wink:
Bernardduur
Someone knows what to do with the trimpots? I have finished the unit (although I still miss the LDR's). I have a working LED part (although the LEDs aren't that bright; maybe that is normal) but the tweaking of the trimpots don't seem to do really much
alessandro
The trimpots work is to regulate the min & max range of the external rate pedal!Enjoy!
It is Sunday morning here - I might just go out to the workshop today and wire up my Voodoo Vibe - I have mounted all the controls and switch and sockets , and i have populated the board and mounted it on the bottom plate of a NSC 1790 case. But then again, it is a nice sunny day and the dogs ( Elvis and Cilla) would probably appreciate a walk in the park more than watching me get high on solder fumes again. :wink:
i am looking forward to hearing the finished vibe though - maybe I will do both :lol:
Those NSC boxes aren't bad at all are they? I've used a couple I got from PedalPartsPlus and they've been good to me so far.
Bernardduur
I tried it with some old LDR's I had laying around.....
doesn't work yet; debugging begins today :)
I have in the chorus mode a vibrato sound, no sound in the vibrato and tremolo
Yet!
Edit; I had the leads on the chorus / vibrato / tremolo mixed up; it works!
