Little VOODOO VIBE project by Kaputepalla  [documentation]
Redhouse
Post by Redhouse »
Redhouse wrote:The link is currently not working, has the zipfile moved? (or does someone else have it and want to point me to it?)
-Redhouse
BTW, I just got here, nice place, glad to be here!
Hello?....
....(sound of crickets chirping)....
greenskull
Has thanked: 33 times
Been thanked: 8 times
Post by greenskull »
Try page 6 for KT66's new layout files with mods. Welcome aboard Redhouse!!!!
Redhouse
Post by Redhouse »
greenskull wrote:Try page 6 for KT66's new layout files with mods. Welcome aboard Redhouse!!!!
Thank you greenskull, I got that and was looking for the original zip file from the first post also.
Redhouse
Post by Redhouse »
Just an FYI, I got that file "Kaputepalla_Little_VoodooVibe_HiRes_PCB_Transfer.pdf" and it seems to have errors not in the other 2 files "little voodoovibe pcb.jpg" and "kt66_final_full_board_photoshop_letter_print.tif".
In case anybody built the Kaputepalla_Little_VoodooVibe_HiRes_PCB_Transfer.pdf board and has trouble getting it going, see these pads are not connected:
Also, I don't know if it's just RM or an internet thing, but the 4th amp in IC-1 doesn't look right, normally an unused OpAmp shouldn't have the +/- inputs shorted and output floating, proper termination of an unused OpAmp helps reduce current draw (in this case a battery).
Normally the + input is either grounded or raised to 1/2 Vdd/Vss and the output is connected to the - input like this:
theyear2042
Post by theyear2042 »
hey redhouse
"Kaputepalla_Little_VoodooVibe_HiRes_PCB_Transfer.pdf" is an old file of mine that is wrong.
if you read my earlier posts in this thread you will see that i mention that several of the pads were discconnected due to a photoshop layer being hidden accidently.
also, that pdf layout has now had several updates done my me and so is redundant. the new layout is called "kt66_final_full_board_photoshop_letter_print.tif" and no-one should build the "Kaputepalla_Little_VoodooVibe_HiRes_PCB_Transfer.pdf" layout that i did becasue it has errors.
"Kaputepalla_Little_VoodooVibe_HiRes_PCB_Transfer.pdf" was removed a long time ago so im not sure where you got it from. please delete it.
the new project files by me are available here:
http://rapidshare.com/files/71272549/kt ... e.zip.html
the project files in the above zip file have been built my me personally - they work 100%
regarding the 4th opamp - that is the way the schem was drawn (by Kaputepalla?) and it works fine. if you mod it, let us know how you get on :)
take care
kt!
greenskull
Redhouse - There's actually another set of pads you missed. In the upper part center where the the 220k and 1M resistors connect. Yeah, I wished I would've caught the updated pcb before I started, but I think I caught everything.
Actually, I'm not digging the tone of this thing after playing around on it for few days. Does all the tricks, but cuts some bass and sounds a bit sharp to the ears. I tried increasing the input cap, but no real improvement. Let us know what you think after your build.
theyear2042
hey greenskull
the bass cutting is in the phase caps
which 4 caps did you use?
the RT-18 caps are a lot bassier 4n7/3n3/2n2/1n0
if you listen to the mp3 demo i posted you will hear a significant bass increase - but then it sounds more like a regular phaser and less like a vibe ;)
you could always experiment with the caps - or use a switcher to switch the caps
kt!
greenskull
Hi KT - Thanks, I took notice of the previous posts, but didn't have a rotary switch handy so I used toggle switches for the last 3 stages. Basically I can get the stock RM, Univox UniVibe and Bajaman versions.
I like Bajaman's a lot because it sounds very even and smooth, but that 470pf is icepicky like you mentioned.... I guess that's why RM upped to .047uf, even though it makes the phasing loppy. I have it all crammed up in a 1790NS enclosure, need to get pic posted before I dismantle it again for more experimenting. My NeoVibe sounds huge and warm compared to this thing, I have a feeling it's gonna be more than the stage caps that need to be changed, but what do I know? I'll post results if I hit gold. Thanks again.
greenskull
Just tried a compressor in front of it and helped quell the piercing tone quite a bit to my liking. Sounding good especially on the neck pickup now. Wish I had room to include that circuit in the same box so I could hardwire it in. :lol:
Hi KT66 or the year2042
I think you may have misunderstood me earlier in this post.
The values for the 4 caps that I chose are in the following order
15n, 100n, 470p, 27n.
I think you may have thought i used a different order :wink:
I do not know what difference placing any of these cap combinations in a completely different order will do to the sound - maybe worth some experimentation :wink:
one thing i do know though - the original 220n cap used in the second stage makes for a very wooly and bassy bottom end - probably okay for organ but way too low for guitar players :!:
The 470p in the 3rd section adds some sparkle to the high end as one would expect - lower this and you gradually loose the high treble response.
I note that this pedal uses 3 x 100n coupling caps between the vibe /chorus/ tremelo switch and last phase stage. I think the original Univibe used 1uf which would explain why the Voodoo Vibe lacks a good bass response - i may try changing these - I will keep the forum posted
Redhouse
Post by Redhouse »
theyear2042 wrote:hey redhouse
take care
kt!
Oh yeah I see it now, thanks. I'm late to this thread and I've got some catching up to do. Thanks for the link, downloading now.
The 4th OpAmp thing isn't a problem, more of an improvement idea.
They say that an unused OpAmp in a dual or quad package will draw current even doing nothing unless the inputs are tied as shown which minimizes it.
Since this is a battery operated vibe (with adapter option) I thought folks might like to know about it.
Here's some appnotes for reference:
http://www.maxim-ic.com.cn/pdfserv/en/an/AN1957.pdf
and page 17.7.3 Unused Sections:
http://focus.ti.com/lit/ml/sloa089/sloa089.pdf
BTW, that TI paper is quite a good read about PCB issues.
Has thanked: 218 times
Been thanked: 857 times
Wondering....
Working on a vibe right now based on the shin-ei but with a somewhat more linear approach on the active elements (and therefore a) overdone b) obvious c) cheaper because of ebay component dumping d) unique :shock: ) I might have the opportunity of dumping all in a 1590B case...
If:
Someone is able to suggest a smaller size ritary switch than the chunky Lorlins....
Help ??
ITT had some - ELV used them in many applications.
But they are only pcb-mount.
Conrad sold them in 2004 as:
70 57 13-33
70 57 21-33
70 57 30-33
70 57 48-33
theyear2042
bajaman wrote:Hi KT66 or the year2042
let us know if this turns out to increase the bass.
thanks
kt!
I just replaced the three capacitors - used 1uf bipolar types for replacements - made a noticeable difference - warmer and fuller bottom end - I will keep them in there :wink:
ps: looking at the kaputella little voodoo vibe layout picture (INPUT GROUND top left and GROUND top right) I replaced the 2nd 3rd and 7th .1uf capacitors along the top row with 1uf bipolar (or non polarised) types.
theyear2042
nice - i will try it out
kt!
theehman
Has thanked: 97 times
Been thanked: 102 times
Post by theehman »
Anybody interested in making me a couple of board sets for this project?
Ron Neely II
fx schematics and repairs
greenskull
Thanks a lot as usual, Bajaman!! I will replace 'em as soon as I have time. I'm really glad you figured out how to improve it.
Happy Holidaze everybody!!!
Redhouse
Post by Redhouse »
theehman wrote:Anybody interested in making me a couple of board sets for this project?
I sent you a PM.
noelgrassy
Post by noelgrassy »
Dirk_Hendrik wrote:Wondering....
If:
Help ??
Try the Grayhill rotary switches. Some are resettable [click positions] and all are built NASA grade. Oh yeah, they're "spendy"...
