Little VOODOO VIBE project by Kaputepalla [documentation]
- Redhouse
Just noticed the LFO section of the "little" project looks nearly identical to Moosapotamus's LFO work, any connection?.
- destro
Don't want to speak for the guy, but I know that when I first set out looking for this project years ago that he had a link for the voodoo vibe project but only had the lfo schem from the circuit....it's been sitting on my hard drive for a bit now. Still waiting to order the vactrols to build this. Can't wait!
That was actually someone else's work from a number of years ago (name escapes me atm). They sent it to me with permission to post and, afaik, it is the very same circuit being discussed here.Redhouse wrote:Just noticed the LFO section of the "little" project looks nearly identical to Moosapotamus's LFO work, any connection?.
~ Charlie
moosapotamus.net
"I tend to like anything that I think sounds good."
Hello!!! I write to them of Argentine, congratulate for this forum, it is excellent!!. It does little finish the voodoo vibe i want to know if there is some photography of the plate finished from already thank you very much!!!.
Pd: does someone know if there are schemes of the H20 of visual sound? Thank you!!!
sorry for my bad english
- gnognofasciani
Does anybody still have a cheap source for the ICL8038?
Search button is your friend
- Contact:
I brought mine from here:
Yeoy
only 2.15 euros a piece.. currently out of stock though, and not sure if they ship outside Finland, but you could try sending them a mail (contact info)..
Yeoy
Moosapotamus wrote:"That was actually someone else's work from a number of years ago (name escapes me atm). They sent it to me with permission to post and, afaik, it is the very same circuit being discussed here"
I was inspired by that old LFO layout on moosapotamus and, looking into the original RMvoodoo-v ,i correct it and added the power supply section and the audio section!Many thanks to you and the friend that has make possible to start this project!
Kaputepalla
Kaputepalla
Torchy
http://www.littlediode.com/components/p ... t=0&page=1
£8.50
http://www.mouser.com/Search/ProductDet ... PsSg%3d%3d
NTE864 = $30.16 !!!
£8.50
NTE864 = $30.16 !!!
- theehman
Ron Neely II
fx schematics and repairs
I found this as well:
http://www.oselectronics.com/ose_p81.htm
They have it for $7.95.
I also found a different one: XR2206, though it's not a direct replacement.
If it's more readily available, it may be worth redesigning the LFO section around it.
- ik6gpy
Does Anyone have the zip file with Single Sided Kaputepalla's PCB, schematic and materials list? The link gives only the double sided PCB of the original Voodoo Vibe. I would appreciate that. Thanks.
Matteo
Matteo
- puppiesonacid
yeah, I too would be intrested in a single sided version.ik6gpy wrote:Does Anyone have the zip file with Single Sided Kaputepalla's PCB, schematic and materials list? The link gives only the double sided PCB of the original Voodoo Vibe. I would appreciate that. Thanks.
Matteo
thanks,
- jrc4558
And (if it's not too much to ask) something that's not posted through rapidshare. It only allows a certain size ofthe file to be downloaded by free user, and the current package is larger than that...
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
This what you want???
members/bajaman/LITTLE%20VV/little%20vo ... %20pcb.jpg
members/bajaman/LITTLE%20VV/Little%20vo ... 0value.jpg
- bajaman
Which files were you wanting
- ik6gpy
Hi Baja, thanks for your patience. I mainly need a schematic to check the rotary switches wiring and a couple of other things (Ac, Av, At, Bc, Bv, Bt pads) i can't understand to what they refer to and how i have to wire the external pedal jacks. the original zip file contains also a bill of materials? Thanks a lot Baja!bajaman wrote:Which files were you wanting
Matteo
